started my new project 1982 911 sc
the first thing i started with was shifting. the shifting was on and off. sometimes good sometimes not so good.
i replaced the front bushings. like to never got it back together.everything kept moving around. took my time and got it. went for a drive. things were a little better but not there. while doing this i am hoping its not the trany. i changed the trans oil today. Swepco 201. not sure if any change. well the only thing left was the shift coupler. i got out my tools out and pulled that sucker out. wrapped it in a rag and went to my work bench. picked the coupler up to look at it and the pressed in pin fell out. i ordered a new one. pin wore to bad, i could make one but the hole rod was egged and the housing was bent. you think this might be the problem with my shifting?
1982 guards red 911 sc work in progress
Why not check out Ivangene's coupler . It has made a huge difference for many of us. I can now downshift 5 to 4 with no effort or wondering if I will get 2nd. Shifting down to and up out of 1st is a breeze, 2nd to 3rd is very positive. Read about it here via search.
15 year PCA member ![]() 1972 911 E Coupe - gone now 1987 Mazda RX-7 2+2 - still cooking Swift DB-1 FF & Swift DB-3 F2000 -not forgotten 1979 911SC 3.0 & 2000 Camaro |
