-   -   front height adjustment (http://forums.pelicanparts.com/porsche-911-technical-forum/708285-front-height-adjustment.html)
vancouver86/911 09-25-2012 07:58 PM
How far can you adjust (raise) the front ride height with the adjusting bolts on a Carrera before the car needs to have a new front end alignment?
JAR0023 09-25-2012 09:46 PM
I just raised my '86 from 24.25" to 25" at the fenders. My level only reads to a tenth of a degree and there was no measureabl change in camber. I had a smidgen (less than a 16th") change in toe. Measured with 22" long toe plates. Depending on where you are starting from I would think one could enconter different amounts of change.
I was confident enough to make the toe correction myself. If not I would have at minimum taken the car and had t checked. Some places will hang gauges and check for cheap if you ask.
J
