-   -   Need help to ID this SC sensor please (http://forums.pelicanparts.com/porsche-911-technical-forum/708550-need-help-id-sc-sensor-please.html)
deeking55 09-27-2012 08:44 AM
Picture one shows a sensor that is unplugged straight back, other sensor on the right is plugged in. I believe one of these is the idiot light for the oil pressure gauge.
Second pic is far right on the engine close to the bumper, again unplugged - what does this do?
I appreciate the help, the PO has changed so much I am still trying to figure things out.
http://forums.pelicanparts.com/uploa...1348764177.jpg
http://forums.pelicanparts.com/uploa...1348764227.jpg
Scott R 09-27-2012 08:46 AM
Which year SC is this? The sensor on the right chain cover is the 50c temperature switch for the lambda unit.
deeking55 09-27-2012 09:13 AM
Sorry -1983 SC that has been converted to carbs. As the lambda unit is unplugged I can assume that sensor is not needed?
Scott R 09-27-2012 09:32 AM
Yea, you don't need any of that stuff for carbs. I should have guessed carbs since you can actually see the oil breather in your picture.
boyt911sc 09-27-2012 10:15 AM
Temperature switches......
The first one on top of the engine near the breather hose is the 35°C/95°F SW and the other at the chain housing cover (right side) is 15°C/59°F SW. Both needed for CIS fuel injection system and disabled for carburator system.
Tony
deeking55 09-27-2012 11:37 AM
Great. What sensor is the one plugged in towards the back with a red top on the first picture?
howard freeman 09-27-2012 12:15 PM
Oil pressure Idiot light.
Howard
