PMB Performance
For most DIY guys and gals out there, leaving them on the car may not be the best solution. It is "extremely" messy and, once you've popped a piston you now have an open system. You'll need plenty of M10x1 plugs to cap off the master cylinder as you move along. You'll also need to plug the open bore which isn't easy on the car. I still like the grease gun as you can remove the tip and most have a 10x1 fitting there to screw into the calipers supply inlet. You can do this more conveniently on the bench and as a fluid, it's rather safe. The piston should "plop" out in your hand vs. air which can come out at bullet velocity. This not only damages fingers but piston tops as well. I've seen countless pistons chipped this way or... WORSE, with plier marks all over them. NO!!! Air can also damage the knockback pin in the opposite bore (if so equipped), bending it and causing your freshly rebuilt caliper to bind. Brake systems are one of those areas on your car that absolutely hate sitting. The plating on your caliper bore wears off over time and, the fluid is hygroscopic (it attracts water). The water gets in your system and likes to gather around the rubber seals. Just below the bore seal is where the piston wears through the zinc. This is where a rusty/old fluid build-up occurs and your caliper now sticks. To be more specific, there are two major areas that rust and bind. 1. Above the bore seal and just below the dust seal. This is usually caused by a torn or cracked dust seal. 2. Around the bore seal itself. This is from the piston wear and then from sitting and hygroscopic build-up. This is why your calipers have to be plated once you pop the pistons out. The bores don't need to be, and SHOULDN'T be honed. Honing creates a completely bare steel bore. We all agreed that most brake fluids are hygroscopic... water "will" re-enter you system and it "will" begin to rust. We repaired a customer's 914-6 caliper that he rebuilt himself. He did a decent job. He replated the calipers and they looked good. There was an internal clip issue but, once we got inside, we saw that he had honed the bore. He rebuilt them one month prior. They were already beginning to rust. If you're rebuilding your own calipers, my very best advice is GET THEM REPLATED. The ATE factory used yellow zinc. Back on topic, once you get that build-up, fluid is just about the only way to get the pistons out. To answer the question of "how water"; we use a hydraulic foot pump that pulls from a reservoir. The fluid is caught in a tray, filtered and goes back into the reservoir. This can pop a piston out in 4-5 seconds. It's not economically sound to build such a contraption for garage use. Just get a grease gun and a couple cans of brake cleaner. IMPORTANT: Make sure you get all of the grease out of the fluid passages. We've had a few cores come in that we didn't know were "greased" and it makes for a non-functional caliper. Also, if you happened to break a dust boot flange, it probably was going to happen anyway. The cocked piston only "enlightened" you earlier to a problem you may not have known existed until you tromped on your binders. I keep meaning to do a caliper build thread... oh how I long for those 34 hour days! ![]()
Eric Shea - PMB Performance 855-STOP-101 We Restore Vintage Calipers www.pmbperformance.com |
FS: 1979 Porsche 911 SC FS: 1992 Volvo 960 Wagon potential sleeper V-8 project 1971 Chevy C-10 w carb 5.3 LS swap 1948 Spartan Mansion 30' travel trailer |
After talking to Eric, I am infuriated that I did my calipers myself. His prices are so reasonable, and the finished product so nice that when it is time again for a refurb, I will box them up and ship them out.
If you get really frustrated, at least there is a good option.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
When you guys are referring to using the car's hydraulic system to push it out, are you switching the brake like over to the bleed nipple? Or simply blocking all the other callipers with wood and pumping the brake?
Senior Advisor
yes last option, be carful as there is a lot of force and the first piston to pop out is the easiest one to get out. thats the limits of using the car system. refilling the master cylinder and maybe getting more air in the system.
08 Cayenne Turbo |
Do I need to be gentile with how much pressure I apply on the pedal? I've read in some brake bleeding threads on here that you need to go only about half way, or is that simply because you're opening the bleed valve with the pedal depressed, and if there is too much force at that point the seal make brake?
No, air is compressible and you only want fluid that is non-compressible.
Pushing the pedal past half way can get the MC seals past their normal travel position in the bore and get into a dirty region that could cause seal damage. Probably not a concern if the MC is relatively new and the fluid has been flushed regularly. I would not worry too much about too much pressure from the pedal. If the pistons are really seized and do not move with reasonable effort, then it is probably far better to send them in to be professionally rebuilt.
Keeper of 911, 912 & 914 databases Kardex source Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
I guess my method is out of left field....
I use ATF.
Drop the caliper in a bucket with ATF overnight. Use a C clamp to collapse it. My grandfather would boil ATF on the fire pit and then pour it in the intake of a sized motor. He not only unsiezed the engine, he would get most running that way. Hope some of you like the old tricks, they still work for me. Cheers, Louie
SHOPPING CART |
Senior Advisor
yes the good old tricks work, even better is to add 50/50 acetone to ATF, the molecules are a lot smaller so it seeps in better
08 Cayenne Turbo |
What about penetrating oil? Also won't acetone damage the dust boot?
Senior Advisor
all rubber parts will be replaced in the rebuild kit, only use brake fluid as a lube to help put in the new parts. ATF and acetone is penetrating fluid. use it for everything stuck
08 Cayenne Turbo |
Thread Tools | |
Rate This Thread | |
