Need some help on Hi-torque starter wiring
So the part I thought would be harder was easy (R&R on the starter), and the part I thought would be easy (wiring) is proving to be a head scratcher. Probably because I'm a dope. I did read and follow the online guide.
Here is what is going on. Got the wiring all connected to the post on the new hi-torque starter except it isn't turning over.
I used the dual spade jumper but no dice. The starter will crank right over if I jump to a hot terminal, so it seems like it is to do with the starter
This car was seriously hacked by the DPO, pretty sure Porsche never used speaker wire for any ignition lines. Any ideas for me here?
I have the thick black cable connected to the post on top of the starter, as are the other lines you see here except for one always live post.
I'm missing the circuit that "excites" the starter...
1967 912 (now w/ 50% fewer random holes in it)
911 w/ 3.2
1974 914 (3.2L swap underway)
1984 928s (S4 engine and suspension), 1987 928S4
Old 10-28-2012, 10:46 AM
Guys - does that look like a 3.2 starter relay even?
911 w/ 3.2
Old 10-29-2012, 12:14 PM
Champagne on Beer Budget
HelmetHead's Avatar
That looks like a universal (or ford style) solenoid?
Einar
www.einarsgarage.com
Instagram @einars_garage
https://www.facebook.com/pages/Einars-Garage/375533809160797
Old 10-29-2012, 12:20 PM
Thanks Einar - so if my other reading here is correct that should come out and I should try to run more of a stock wiring configuration to the new hi-torque starter?
911 w/ 3.2
Old 10-29-2012, 12:23 PM
HelmetHead's Avatar
The high torque starter should have two terminals..one large threaded for battery power and a spade terminal for the ignition switch. I don't quite understand why there would be a secondary solenoid.? Here's a photo from under my car of the two terminals on the starter. Perhaps the PO put a second solenoid to act as a battery cut off switch to the starter?
Einar
Old 10-29-2012, 12:29 PM
tobluforu's Avatar
Is that an old hot start solinoid?
Old 10-29-2012, 12:43 PM
Originally Posted by tobluforu View Post
Is that an old hot start solenoid?
Not sure, I suspect that the DPO put that in as a work around rather than solving the core issue.
So I have the large battery wire connected directly, will try the other lines removed from this DPO solenoid and see where that gets me?
911 w/ 3.2
Old 10-29-2012, 12:49 PM
Here's a starter wiring diagram as it relates to installing a relay on the ignition switch side, mainly to save wear and tear on the increasingly costly ign. switch.
BTW, there's no/little difference between the starting circuits of a factory and a torque-reduction starter. I think you have all the basic ingredients in that closeup photo.
The small screw post looks to be the no. 50 terminal for the ignition switch wire (Yellow). Perhaps you can upload another pic that includes more of the related scene and at a slightly different angle to observe the other terminals, wires and connections.
Remote Starter
Sherwood
Old 10-29-2012, 06:47 PM
Wer bremst verliert
JohnJL's Avatar
Is that stereo wire?
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 10-29-2012, 09:35 PM
LJ851's Avatar
Old 10-29-2012, 09:40 PM
Originally Posted by LJ851 View Post
Yeah, speaker wire. Thin speaker wire..nice, eh? I've got some work to do.
911 w/ 3.2
Old 10-29-2012, 09:47 PM
What's connected to the speaker wire, or is it just passing by?
S
Old 10-30-2012, 07:10 AM
S
Need to run that down still - probably something important like the ECU to engine controls if the DPO was consistent. Ugh.
Here is some of what I already dealt with...
911 w/ 3.2
Old 10-30-2012, 07:32 AM
tuchan's Avatar
Send a message via MSN to tuchan
If the starter turns over when it is "hot wired" then you need to look at the circuit with the yellow wire. You may have upset it when pulling out the alarm and what not.
Goose- "nothing a year in the tropics wouldn't fix"
Old 10-31-2012, 02:07 AM
