biggtbiggt's Avatar
1980 sc maf?
I have been fighting with the herky jerkys on a new to me car. It is a 1980 911SC 3.0 The car had been sitting for a 3-4 years but had been run a a few hrs every year. When I got the car it had a severe up and down idle problem and severe herky jerky. I have replaced the spark plugs and leaned it down with the 3mm. I think I have the startup idle under control and am pretty close on setting. The po said he had overfilled the oil and it is still missing a bit and feels like my harley did when the maf was bad. I was wondering if this car has a sensor that could require cleaning and where it is located? Thanks in advance ...Tracy
Have a good day eh!
Old 08-19-2012, 04:48 PM
Fleabit peanut monkey
Bob Kontak's Avatar
No MAF sensor on an 80. You probably are sucking false air. That means any air leaks past the air sensor - that is the circular lift plate that is to the right of the throttle body. The air sensor (lift plate) is the old version of today's MAF.
Cool you have a Harley. You know 98% of Harleys are still on the road..........the other 2% made it home.
Seriously, there are a lot of folks that can help you out here. Look for vacuum leaks. Also get yourself some fuel pressure gauges. Do you have an oxy sensor?
Old 08-19-2012, 05:12 PM
biggtbiggt's Avatar
Yup on the oxy sensor
I have an oxygen sensor but have not looked at it yet. I will have to measure the voltage output from it sometime. I have sprayed it down pretty good with propane and ether around all the visible potential vacuum leaking spots but could not find any leaks. It really slows down when I pull the oil cap off.
Have a good day eh!
Old 08-19-2012, 05:37 PM
Guardsred911's Avatar
Check the Oxygen sensor. I was getting the same behaviour and replaced the relay per Bob's suggestion. Runs like a champ now.
J
911 SC - 1980
911 S - 1977
Old 10-02-2012, 11:27 AM
Fb = M/S
aoncurly's Avatar
Just unplug the O2 sensor and see if your car still hunts at idle. If it stops, chances are your O2 sensor is bad and needs replacement.
Old 10-02-2012, 02:03 PM
