^ Box-end ratcheting wrenches would probably work great with the all-threaded rod, allowing quick compression before the bushings cool.
I've been trying this method (threaded rod) on my '71T, but I'm having difficulty with the rear bushing. I'm using the URO high density bushings, heating in boiling water and using dish soap for lubricant. I was able to install the front bushing after 2 trys, but the rear keeps pulling into housing. I've tried the method in the instructions (1/2 way into the housing, then onto the control arm); all the way into the housing, then onto the control arm; 1/2 onto the control arm, then housing; and all the way onto the control arm, then housing. The housing and control arm were cleaned and sanded with 600 grit.
Any suggestions? Thanks in advance for your thoughts. dho |
Pretty nifty little rig that makes light work out of the task.
I suggest RSR bushings, much nicer solution IMHO. https://uploads.tapatalk-cdn.com/202...09308b47d3.jpg
https://uploads.tapatalk-cdn.com/202...8105ff64f4.jpg Everything about these are easy…..and very smooth operating too. Sent from my iPhone using Tapatalk |
That way the end of the bushing is supported inside the housing while it's being pressed onto the arm, so that the bushing can't get pulled into the housing, similar to ER's tool. Their tools definitely make the job easier, but tools cost money and we're trying to keep the price down on our kit. |
Thank you for the suggestions. I was finally able to get them to seat after several tries.
Dho |
| All times are GMT -8. The time now is 01:32 AM. |
