ausgezeichnet's Avatar
Spark Plug Condition
Guys,
How do these plugs look.? I thought I might have been running a little rich or I might have had a fowled plug, but these do not look too bad.
Mike
Mike
'84 911 Carrera Coupe (totaled)
'83 911 SC Coupe
‘06 Aston Martin Vantage V8
Old 09-24-2012, 11:36 AM
The Dude abides...
bigel's Avatar
Hard to tell from the picture provided, but they appear to have normal wear with the exception of the two on the far right.
'03 Carrera 4S
Old 09-24-2012, 11:42 AM
emac's Avatar
Mike
In my opinion #5 looks "dirty" that could be your fowled plug. Check your cap, I just did a tune up and found a bad wire. When I looked in the cap on top where the wire plugs in I was shocked to see all of the crud and burn marks.
Ernie
Ernie 81 SC
Old 09-24-2012, 11:45 AM
Found a bad wire on #5. Thanks. They are Clewett wires. I have not been happy with them . Just ordered a set of Magnacor 8.5mm wires.
Mike
'83 911 SC Coupe
Old 09-24-2012, 01:20 PM
emac's Avatar
That's what I had on mine not happy with them. Magnacor much better
Old 09-24-2012, 02:00 PM
T77911S's Avatar
those dont look bad enough to be fouled.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-25-2012, 04:58 AM
db_cooper's Avatar
If these are out of your 1984 3.2 they are fine and not fouled..they are just uneven. A bad wire on #5 explains its appearance. #2 and #3 are even colored.
With an air cooled engine, a remote distance photo of the plugs and no telling if the engine was cold and idled for a while..the uneven plug coloring is not a good way to read spark plugs.
Just for fun, check your intake gaskets for leaks. 3.2 engines eat them.
Old 09-25-2012, 07:25 AM
Just completed a valve adjustment and oil change. Replaced the spark plugs, ditributor cap and rotor. Also replaced the Clewett spark plug wires with Magnacore 8.5mm wires. The car runs like a champ. Good power though the entire RPM band and very good throttle response. It is the best it has run in the 6 years I've owend it.
DB_Cooper: I replaced all the intake gaskets about 5,000 miles ago.
Mike
'83 911 SC Coupe
Old 10-02-2012, 09:28 AM
