LinkBack | Thread Tools | Rate Thread |
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
Author of "101 Projects"
Sorry if the article is not clear. The torque-spec refers to the small nut on the top of the ball joint, not the big one at the bottom. I will modify the article to make this clearer.
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
I'm having trouble visualizing any nut on top of the ball joint. Do you mean the nut on the horizontal ball joint pin? My experience is on 66-89 911.
gary 70T coupe forever almost done 88 Carrera Targa diamond blue |
There is a "wedge bolt" that holds the top of the ball joint shaft in the bottom of the shock tower. The other is the large nut on the bottom of the ball joint that holds it in the open hole of the A Arm. This larger nut is torqued at a MUCH higher spec, something like 185 foot pounds.
In the process of replacing these myself...getting them off can be a major PITA.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Thread Tools | |
Rate This Thread | |
