-   -   Removing trans from engine( 930) (http://forums.pelicanparts.com/porsche-911-technical-forum/70977-removing-trans-engine-930-a.html)
Bobster 06-09-2002 05:06 PM
I have removed the 4 bolts but cannot remove the trans from the engine?? seems like it is hung up on the relaes fork???? do I have to release the clutch throwout fork? if so how do I go about that? thamks in adavnce
ChrisBennet 06-09-2002 05:45 PM
The clutch levers need to come off the transmission. With the lever on the clutch, the fork can't swivel enough to come off the throwout bearing.
-Chris
Bobster 06-09-2002 08:45 PM
Thanks Chris for the info........removed the arms and Bingo!!
