Gentlemen,
Why does the car need the CDI to run? Could you not just add condenser and pull power from the line running to the CDI? Please let me know your thoughts on this. By the way new CDI Bosch $ 1,350.00/ rebuilt box $ 600.00. Thanks, Tom |
MSD6AL + BlasterII is an inexpensive alternative.
The CDI is how it was designed for precise high energy ignition control. I'm sure you could jury rig a condensor points system, but why go backwards in design to the 60's? Where would you mount a condensor in your dizzy? |
By the way is the old Perma Tune box worth anything?
Tom |
Appraised value......
I won't even keep a good working 'Permadoom' as a spare or back-up unit. What more for an old tired unit? Someone might buy it to cover the shipping and handling expenses. But don't throw it out to the dumpster. Tony |
In my case the red relay was loose and not making good contact... I expanded the tips and it went in nice and tight and the car started without isses... This of course, was after replacing injectors, fuel pump, and almost taking the engine out!
KISS Another time I thought it was the CDI... Got an MSD... Sent the CDI out for repair and they told me it was fine....turned out to be a bad coil, so stock CDI went back in, repleced the coil and car ran fine... MSD new inthe box, maybe to be used in the future.... KISS So check the basic stuff before pouring money in parts... |
| All times are GMT -8. The time now is 01:36 AM. |
