Seat Switch Removal
Hey, quick question, I couldn't find in previous threads. I'm swapping out a bad seat adjustment switch: Does the switch come out the front of the face plate or the rear? Is it simply held in with friction tabs?
Thanks in advance Cheers, Jay B. |
Virginia Rocks!
Here's a photo. You might not need to replace the whole thing. You can disassemble and clean the parts. To hold the ball bearings, add some white lithium grease to the springs. It'll hold it as long as you need to get it back together.
Need help with seat switch
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
Swapper and Ruiner
It comes out the front. You have to depress in the tabs from the rear and push it out from behind. The only way I was able to get it to work was to take the whole seat out of the car.
H
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/502929-diy-iroc-rsr-conversion.html http://forums.pelicanparts.com/porsche-911-technical-forum/649179-rsr-ls-conversion.html |
