jhlasserre's Avatar
Zenith VS. Weber
Enlighten me here. I got a field find 911T with Zeniths. How do these differ from webers. Why did Porsche decide to use them? Cheaper? I know there are two methods of adjustment per Weber or Zenith.
Is there a clear advantage to either? Can you switch between the two?
Thanks, Josh
Old 10-09-2012, 08:28 PM
ASE Master Tech - 35 yrs
larrym's Avatar
zeniths are somewhat limited if you plan to do major engine upgrades - lots more parts available for the weber
both bolt to the same manifolds
if you are leaving it stock or almost so, the zeniths will be fine
and a lot cheaper
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 10-09-2012, 08:47 PM
kkinzli's Avatar
I have Zeniths on the Rat and it runs very well. For your purposes I think they will be fine. The Webers are indeed a lot more expensive but can be adjusted for engine upgrades. For a stock engine the Zeniths work great.
1969 911T - The "Rat"
1997 A4 Quattro 2.8 (270k) - Black Kaniget - Dead but not forgotten
2010 Jetta TDI Sportwagen - Egg Butt (also Spewing Dragon)
2001 Eurovan Weekender - Bruni
Old 10-10-2012, 05:43 AM
T77911S's Avatar
not a lot to base it on, but i think the zeniths are better than the webers,,,,,for engines they can be tuned for.
my brother had a 2.4T with zeniths and that thing was quick. it seemed faster than my 2.7.
i also had a 2.2E with webers, in a 914. it seemed like the zeniths were just a bit better.
just my limited opinion.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 10-10-2012, 11:45 AM
neilca's Avatar
I use Zeniths on the race car, 36mm chokes for a stock 2.0L and worked great.
Old 10-10-2012, 02:32 PM
