Guardsred911's Avatar
Jack Tie Down Strap
Hi! I have a 1980 911 SC. I was looking to better understand where/How the jack should be mounted to the body for a stock configuration.. which I certainly don't have.. the PO just wrapped it in a towel and wedged it by the spare... Is the strap available on the pelican site? I haven't been able to locate it....
J
J
911 SC - 1980
911 S - 1977
Old 10-08-2012, 10:14 AM
Go-Kart Mozart
JAR0023's Avatar
Here are some part numbers from PET.
911.722.021.01 for the rubber strap (Porsche calls this a bracket)
911.721.131.00 rubber wedge (Porsche calls this a clamping piece)
Jack stores horizontal on the back side of the front bulkhead. There is a shelf to the left side and a metal piece that catches the base of the jack. The wedge sits here. The jack lays on top of a tab about the centerline of the car and the rubber strap keeps it in place. On my car the jack installs with the handle facing rearward.
J
Old 10-08-2012, 10:25 AM
Go-Kart Mozart
JAR0023's Avatar
Ouch!
Old 10-08-2012, 10:28 AM
1984 911 Targa - "Sabine"
Skip1's Avatar
The part I believe you're thinking of is a "auto jack bracket" 911-722-021-01. Pelican lists it at $47.00 but is Porsche OEM. Never ordered one, but...
It fits into a small crevis under the front ledge of the hood forward of the spare tire against the vertical portion of trunk area. I believe it's a small rubber strip with two metal loops - pricey piece of rubber.
Skip
1984 (RoW) 911 3.2 Li Carrera - "Sabine"
2011 Cayenne S
Old 10-08-2012, 10:30 AM
donagain1's Avatar
Old 10-08-2012, 10:34 AM
Go-Kart Mozart
JAR0023's Avatar
For $47 I think I could be content with a suitable rubber o-ring holding my jack in place.
FWIW a lot of ATVs and MCs have a similar strap holding in a small tool kit. Might be worth a trip to a mototcycle shop.
ETA: Ebay link...sorry Pelican.
tool kit strap | eBay
J
Old 10-08-2012, 10:41 AM
Northern Motorhead
wildcat077's Avatar
Like Jar says,two of my ATV's have similar rubber straps ... definitely check out a bike shop,i'm sure they are way less than $47.00 dollars !
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 10-08-2012, 12:03 PM
kshafer1's Avatar
Can someone provide the length of this rubber strap? I'm sure one of the motorcycle battery straps will work.
1979 911 SC Coupe
2000 VW Passat 1.8T
Old 10-08-2012, 06:33 PM
Go-Kart Mozart
JAR0023's Avatar
Mine measures 6" outside edge of clip to outside edge of clip. Rubber strap measures 3.5" at the clip attachment points. Very little stretch to get it attached. (E.g. you could go shorter if the strap has plenty of stretch.)
J
Old 10-08-2012, 08:26 PM
kshafer1's Avatar
Thank you. I ordered a 5" battery strap for less than $5. Time will tell if it works. Thanks to the OP for bringing this topic up. I've only had my 911SC for two months and had wondered where the jack was supposed to mount.
1979 911 SC Coupe
2000 VW Passat 1.8T
Old 10-08-2012, 09:06 PM
Registered Ass-hat
Mehoff's Avatar
Im pretty sure i still have that thing attached to my race car, though i have no idea what condition it is in. Ping me the first weekend in december (next time i'll have the car out of storage) and i'll pull it off gratis for you if you want it.
Old 10-08-2012, 11:59 PM
