Late Seats, Early Car - Adapters
Don't know if anyone needs them, but I've attached a high resolution diagram of the rails / adapter plates to fit 84-95 seats into a early car / longhood.
Cool! Do you have this in a CAD drawing ... a DWG or DXF? need something with dimensions on it.. also what thickness plate is good to use?
Thanks! |
Sorry, don't have it in DWG or DXF, I could probably convert the file though - pm me with your email. The file is sized at 100%, I printed the lineart onto a self adhesive sheet and stuck it to the metal, the plate I used was 2.25 inches wide, and an eighth of an inch thick. Drilled them, shaped them, primered and sprayed them with a black enamel, they work a treat and look 'right'. Lowers the seat slightly too.
