Post 2.2 liter removal?
I know this has been discussed in the past. But can you just remove the engine from the the tranny on a 70 911T? TIA
Old 08-13-2001, 11:01 AM
Senior Member
orbmedia's Avatar
Post
Since it has the pull type clutch it is harder to separate the engine/trans. Since I always remove the whole powertrain anyway it's not an issue. If you want to remove just the engine you are going to have to be able to get a screwdriver or something into the starter hole to rotate the TOB, a bear!
Old 08-13-2001, 12:41 PM
