NotoriousDAN's Avatar
78 sc axle replacement, wheels don't turn
hey everyone, just had my axles rebuilt by a local shop and on installation , while connecting the axle to the wheels once tight the wheels do not move. car is in neutral and the hand break is off. Any idea what i'm missing?
1978 911Sc
Old 10-08-2012, 11:04 AM
I'd take the axles off and check the CV joints do actually move like they're supposed to.
You can (mis)assemble the joints in such a way that they physically fit together but only have a very limited range of motion. Which might be just enough to bolt them on the car, but then they'd lock.
'77 S with '78 930 power and a few other things.
Old 10-08-2012, 11:39 AM
I would rather be driving
jpnovak's Avatar
Did you use new mounting bolts? If so, they might be too long. If the mounting bolts are too long they will bind on the transmission case and not turn.
Old 10-08-2012, 11:50 AM
If your axles were rebuilt using the newer boot\flange cover (almost a certainty, the original boot/flanges are NLA), the original length bolts are too long (the new flange cover is thinner); you must use shorter (45 mm ?) bolts.
Jerry M
'78 SC
Old 10-08-2012, 12:08 PM
