thebondman's Avatar
Send a message via ICQ to thebondman
Dyno Results from a 1985 Targa 3.2L
Absolute Barometric Pressure 29.54 in.HG.
Vapor Pressure 0.45 in.HG.
Intake Air Temperature 85.7 deg F
Gear Ratio 55.63 RPM/MPH
Correction Factor 1.02 SAE
207 Max HP186.3 Max Torque114MPH@6200 RPM (set redline)
Air/Fuel Ratio Average 14.2 (lean?)
The mechanic at the shop said that the air/fuel was lean. Is there an adjustment for
the air/fuel mixture on a Motronic System? If so, please advise. Thanks
BILL
"If you're not living on the edge, then you're taking up too much space."
My 1979 930
1979 930- 3.4L Andial Racing P/C's/Fuel Enrichment System/Adjustable Boost Control,Euro Fuel System,Group B Cams,K27 Turbo(1.0 Bar) Andial Intercooler, GHL Muffler/SS Header Sys,Welt. SS Kit/Camber Brace, SS Brake Lines, 350mm Momo, Billet Pedals, 9x17 - 11x17 Fikse.
1999 FXSTC- Harley Davidson HI-4 Ignition,Thunderball Cam,Mikuni 42mm,Vance & Hines
2003 Jetta Wagon GLS 1.9L TDI
1993 GMC Jimmy 4x4
St. Louis PCA - Member
Kirkwood H.O.G. Chapter #2573 - Member
Gateway H.O.G Chapter #1337 - Charter Member
Old 06-10-2002, 10:30 AM
