Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
How to remove fresh air blower plastic fan from motor shaft??
Trying to Mcgyver my fresh air blower before just ponying up and buying a new motor. Makes an awful squeaking racket when it decides to work. I pulled out the whole assembly and determined it's the lower bearing making all the noise. I'd like to lube it up and see how much better it gets. Looks pretty grungy at the moment.
So how do I pull the plastic fan off the motor shaft without breaking it? Doesn't look obvious to me and don't see any set screws. Is it just pressed in place?
Any recommendations on lube? Axle grease, teflon bike chain lube, WD-40, olive oil??? (okay that's a stretch but it's all I have in the house at the moment).
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 10-10-2012, 05:34 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
steely's Avatar
I'd recommended getting something like an electric motor oil, 3-in-1 makes one and so does liquid wrench.
No on the grease and WD-40.
Sry can't answer the fan pulling question.
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 10-10-2012, 06:53 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
ROW '78 911 Targa
timmy2's Avatar
Mine was noisy so I sprayed it clean with contact cleaner and lubed it with a light lithium type spray oil, without pulling blower off of shaft. Works great.
Old 10-10-2012, 07:30 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Weekend Mechanic
vulcan300's Avatar
Insert a hefty flat blade screw driver under the squirrel cage. Twist the screw driver and it will start to force the squirrel cage off the shaft. Once it starts moving it is fairly easy to remove.
86 911 Carrera Targa
Old 10-10-2012, 07:56 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
sit down and support the fan with your legs/knees. the shaft usually protrudes a bit beyond the plastic. get it started by knocking it flush with a small hammer. then use a punch to finish the job.
jwworkshop@aol.com 206 789 6800
7613 greenwood ave n seattle wa 98103
Old 10-10-2012, 08:46 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
83 911 Production Cab #10
JJ 911SC's Avatar
PM me an e-mail address and i'll send you step by step for motor replacement with pics and the do's and dont's.
Can remember if I posted this, if not I should
Who Will Live... Will See
83 911 Production Cab #10, Slightly Modified: Slanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger
Old 10-11-2012, 01:04 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Thanks... I'll give those a shot tonight when I get home. I'm thinking a little bit of cleaning and lube will save me the $100 for a new motor.... at least for a little while.
Old 10-11-2012, 03:20 AM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
i bought a used blower and replaced my old one. i took the old one apart if you need any parts. the motor was siezed up on it.
Charles
79 930 #632
88 911 Cab
74 TR6
88 CRX Si
Old 10-11-2012, 03:49 AM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
Senior Member
Jdub's Avatar
Lube-wise Phil's Tenacious Oil is a nice split between the lighter oils (TriFlow, 3 in 1) and the heavier grease you will never want to use.
Be sure the fuse for your blower motor is in good nick and the correct one. Stories of these fans overheating and whatnot seem legion.
'78 Targa | Horizontally Opposed
Old 10-11-2012, 07:15 AM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
