Location: behind the redwood curtain, (humboldt county) california
"Best" suspension part refinish???
Dad's 74 is undergoing a brake & suspension overhaul. Not a track rat or concour, but i want to do a good job re-doing things.
I've used paint thinner and a stainless brush on the front hubs, but still have a fair amount of crud around the studs. Is some kind of blasting verboten??? New bearings going in after.
The front rubber bushings are off of the A arms and the paint is looking kind of scruffy. So, sand/media blast to get the old stuff off, then red oxide primer and a couople of coats of Rustoleum Or POR, with some kind of primer???
There are no more "platers" up here behind the redwood curtain, (humboldt county), so how do i refinish the late model adj spring plates?? Calipers, (iron).
Dazed and Confused,
chris
I am absolutely sure god didn't want something like this to go back on one of the good doctor's fine autos.
Old 10-22-2012, 05:36 PM
rw7810's Avatar
you can bead blast the outside, just keep the bearing races covered.
Robert Williams
70' 911T
Old 10-22-2012, 06:43 PM
steely's Avatar
I had a powder coater do my control arms. I believe the spring plates are cad plated (or yellow zinc chromate?) If you do a search I know this has come up before.
My powder coater was local. I mailed one item (non - suspension) to a finisher that was out of state. (electroless-nickel plated the fan)
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 10-22-2012, 07:19 PM
Sorry, not trying to steal the thread.
Steely,
I would like to know what your electro. plater did. I understood that you cannot plate magnesium, which is what the fan is made out of. You can powder coat magnesium, but not plate it.
Just curious. Thanks,
Mark
08 Aston Martin Vantage V-8 (6 spd manual) (DD)
20 Cayenne white-black/red (hers)
78 930 (heavily modified)
08 GT3 RS (white/black) (modified of course)
67 911S outlaw (sold)
Old 10-22-2012, 07:43 PM
steely's Avatar
With apologies to Chris...
Mark, I had it EN (electroless-nickel not chrome) plated at Magplate.
Idea from here:
Nickel Plated Fan & Housing
Mine is post 14 here:
Show me your...Fan!
Feel free PM me if you have any questions.
Dan
Venetian Blue
Old 10-22-2012, 09:12 PM
Garage Queen
PorscheGAL's Avatar
I have just ordered a home zinc plating kit with cad coloring from Caswell Plating. I have not had a chance to try it but lots of videos on YouTube.
I would say that if you want to pay someone to zinc plate, you will probably need to mail it off. I have a guy in Augusta Ga who has done some for me in the past. PM me if you need his name. An example of work he has done for me.
Stephanie
'21 Model S Plaid, '21 Model 3 Performance '13 Focus ST,
Off to a new home: '16 Focus RS,'86 911 Targa 3.4, '87 930, '05 Lotus Elise, '19 Audi RS3,
Old 10-23-2012, 03:22 AM
cycling has-been
bkreigsr's Avatar
Get a couple of abrasive ball' s (scotch brite type) for a Dremel from McMaster. They come in three grades of courseness.
Plus, all that crud will eventually come off with some effort, even with lacquer thinner or diesel fuel with no ill effects to the metal.
Bill K
Old 10-23-2012, 06:26 AM
Home of the Whopper
I used POR-15 on most of my suspension parts. Tough stuff. Media blast, prep and paint per instructions.
That front hub will look almost as new when media blasted.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 10-23-2012, 06:36 AM
French Import
zippy_gg's Avatar
Cool! Could you post some pics once you have plated some of your parts? That sounds interesting and fun. Thanks!
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 10-23-2012, 07:20 AM
Thank you Stephanie, Bill & BK9111,
I will try the media blasting, Por-15 & look up Caswell's home kit.
Thanks,
chris
Old 10-23-2012, 07:22 AM
Dazed and Confused,
chris
Seriously, there is so much going on in the hills there is surly a plater somewhere. I know there are several single stage painters up there steadily working. Ask around the shops and I bet a name will turn up. Now it may be a bit like "Deliverance" when you get there but.............
Free will is doing what we must joyfully.
Jung
'68 912 Coupe
'82 SC sunroof
Old 10-23-2012, 09:02 AM
Try an overnight soak in a bucket of carb cleaner. Works wonders. Wear gloves, rinse with hot hotter.
Sherwood
Old 10-23-2012, 01:43 PM
PMB Performance
Eric_Shea's Avatar
For the hub, it will need to be media blasted and "re-anodized".
Leave the old races in for the media blasting and take them out before having them anodized.
If you only media blast them, you will take much if not all of the anodized coating off the hubs. They will begin to corrode very quickly after that. Porsche wheels, alloy calipers and hubs were anodized clear.
For the suspension itself, I like "Zero-Rust" (Google it) over powdercoating. A couple of reasons: 1. It does not cake up like powder and powder can cause problems when attempting to reattach brake lines and hoses in this way. 2. It is spec'd out to spray directly on bare metal. 3. I had the luxury of having a set of control arms returned for new bushings. The arms had been on the car for 4-years. The Zero-Rust coating looked like new.
Here's a set of control arms we restored for Pete Stouts beautiful 914. You can see the Zero-Rust" coating finish on them:
https://www.facebook.com/media/set/?set=a.10150589053973193.379616.72240238192&type=1&l=85d9a87428
Eric Shea - PMB Performance
855-STOP-101
We Restore Vintage Calipers
www.pmbperformance.com
Old 10-23-2012, 03:04 PM
AutoBahned
RWebb's Avatar
does the "Zero-Rust" coating resist rock impact chipping as well as powder coating?
Old 10-23-2012, 03:23 PM
PMB Performance
Eric_Shea's Avatar
Hard to say. The control arms we got back looked new. Not sure of the use or mileage. I've found it to be extremely durable though. It bonds to the bare metal. They do not suggest a primer.
It is thinner which is actually a benefit for fitting rear end caps into crossbars and the brake line hoses and clips as mentioned.
855-STOP-101
Old 10-23-2012, 03:41 PM
