-   -   No moly grease on slave push rod? (http://forums.pelicanparts.com/porsche-911-technical-forum/71146-no-moly-grease-slave-push-rod.html)
Rick Lee 06-11-2002 06:08 AM
Another thing that eats away at me at night is the fact that I forgot to put some moly grease on the push rod of my slave cylinder when I reinstalled it this weekend. I am not about to go through that slave R&R with engine and tranny in the car again. I really messed it up a few months ago. This time it was easy with the tranny a few inches lower. Is it a big deal to leave the grease off the push rod?
Roland Kunz 06-14-2002 02:23 PM
Hello
Very big deal sure.
maybe it will make sounds or the pushrod will wear the pan in the fork out. Most peole wouldn´t care.
To have a good sleap again remove the rubber flap and use a long nozled teflon sprayer ro ad some sticky teflon grease.
But you sure have grease on the fork lever shaft and some grease on the guide tube ?
Grüsse
Rick Lee 06-14-2002 02:30 PM
Yes, we did grease the fork shaft and guide tube. I'll grease that push rod this weekend. Vielen Dank Roland.
Roland Kunz 06-15-2002 06:02 AM
Hello
OK that was a partial joke ;)
No need to rush as you see that often when you renew the clutch on a old car. As long there isn´t dirt it will not hurt the function.
Grüsse
