Constitutional Liberal
Is this an "S"?
I found a Porsche in a storage unit and the chassis # is 305705.
I checked the engine # and it's a normal but the books seem a little ambiguous on the chassis number. Thanks for the help.
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
If the chassis is an "S", then the VIN will have the letter S stamped at the end. The number you posted, if that is the complete number, is for a normal.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
Regenerated User
Check the engine stamp
Porsche Engine Numbers Here's a pic of my '71 S engine. (Now if I could only find the S car) ![]()
My uncle has a country place, that no one knows about. He said it used to be a farm, before the motor law. '72 911T 2,2S motor '76 BMW 2002 |
a 1967 normal from a quick check of the spec book. still worth $$$
Regenerated User
What's an early S worth?
72 911 Although it is done at the moment, it will never be finished. |
muck-raker
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Hi Doug,
I see you posted this question in the Classified section about the 2.4L S coupe currently on eBay that is bid to $140K. You might want to start the same discussion in the Market Place section. Porsche Marketplace Discussion - Pelican Parts Technical BBS You will no doubt start a lively debate there. ![]() As to the 2.2S on the Samba, I would love to see that car go back to it's original color of Conda Green with a Cinammon interior, but that is a full restoration to do that so I don't think the asking makes sense yet for that one IMHO.
Brian '73 Carrera RS '71 911S coupe 'Patrick' '16 Cayman GT4 '91 C4 coupe |
Taking it apart is easy
How does this happen? Sounds like an upscale version of dumpster diving.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
Regenerated User
Matching the car and the engine is the key though, what about just the engine 2,2S, or a non-matching 2,2S in a T?
[EDIT] I'll repost on mkt plc
My uncle has a country place, that no one knows about. He said it used to be a farm, before the motor law. '72 911T 2,2S motor '76 BMW 2002 Last edited by 72doug2,2S; 10-19-2012 at 09:06 AM.. |
Ayo Irpin, Ukraine!
That's how my car was found down in Bakersfield. The gentleman whom I bought it from had won the contents of a storage unit in a lien auction. The car was inside.
Harmlessly passing gas in the grassland away; Only dimly aware of a certain smell in the air |
