Shift Knob Removal - Any Trick To It?
How the heck do you get the shift knob off an SC? I have nice new one to put on. I've tried several variations of pulling and twisting - but to no avail. Is there a trick to this? Is it, by chance, a crushed sleeve installation thereby rendering it virtually impossibe to remove? It doesn't feel threaded. I don't want to reef the whole darn linkage out of the tunnel!
Old 08-08-2011, 10:13 AM
schumicat's Avatar
sometimes the crush sleeve is basically frozen to the shift lever, and the knob will break into pieces before it comes off.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 08-08-2011, 10:25 AM
Make Bruins Great Again
Por_sha911's Avatar
How do i remove the shift Knob????
The search button is your friend.
Joe
Old 08-08-2011, 10:28 AM
scottb's Avatar
Take a crescent wrench....loosely under the knob. Tap it up with a hammer. It has a pressure "crush sleeve" holding it on to the shaft unless some wanker glued it on. The shaft is tapered....you may still destroy the knob but it is NOT threaded.
I wouldn't use a Crescent wrench...a regular open-end wrench is better. Pounding a Crescent wrench might break it.
1984 Targa
Old 08-08-2011, 10:29 AM
Thanks guys - I'll give it a try. If it breaks, well, what the h**l.
Old 08-08-2011, 10:39 AM
scottb's Avatar
Be careful when pounding -- if you miss while swinging the hammer, damage (to you or the car) might result. Also, the knob sometimes flies off, so you might consider putting a towel over it while you're pounding.
When I removed my shift knob, I used a dead blow hammer with an open-end wrench (15mm?). Worked pretty well, IIRC.
1984 Targa
Old 08-08-2011, 10:42 AM
nkotselas's Avatar
I've been having the same problem,
All I want to do is put on a leather boot on my shifter, should I do this or take out the entire shifter? How do you do that?
Nick
'78 Turbo Look w/ euro 3.2
Old 08-08-2011, 12:03 PM
French Import
zippy_gg's Avatar
See if you can find a lace-up boot that won't require any disassembly.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 08-08-2011, 12:30 PM
FPB111's Avatar
Throw a towel over it before you wack it. So you have less chance of launching it through your windshield or fore head.
2013 991.1 Carrera S Cab
2004 996 Turbo CAB X50 sold
2003 996 cab 6 speed Sold
1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold
DE instructor since 1985
Old 08-08-2011, 12:49 PM
emac's Avatar
Save yourself a breakdown I tried for two days. Ended up cutting it off.
Old 08-08-2011, 12:51 PM
looks like an opportunity to produce a special tool. a slide hammer with a fitted fork that supports the bottom of the knob well enough to not scar or break it. every shop should have one.
206 637 4071
Old 08-08-2011, 12:53 PM
schumicat's Avatar
you would have to take out the whole shifter and partially disassemble it. it is not that hard and directions are in the 101 projects book and various shop manuals. I'd do that before trying to get the knob off with anything other than your hand.
Old 08-08-2011, 01:02 PM
nkotselas's Avatar
Thanks, I have some books i'll look through.
But I would try not cutting off the knob if possible, they do sell for $100 to $200!
Nick
Old 08-08-2011, 02:39 PM
May I insert a product plug?
Yet Another Shifter Thing
One method involves removing the shift knob as described above.
Another method avoids potentially destroying an expensive knob by cutting the lever and inserting a splice extender.
Sherwood
Old 08-08-2011, 03:29 PM
Dublinoh's Avatar
Ok, I resurrected this thread because I can't seem to get the shift knob off of my 1987 Carrera. I saw somewhere that the G50 shifter did not need a crush ring to install a new knob. Do you do something besides "beat" it off the shifter? I don't want to cut or destroy anything to get it off. Help?
Old 12-13-2011, 01:38 PM
scottb's Avatar
Doesn't the G50 knob have a set screw under the emblem?
1984 Targa
Old 12-13-2011, 01:51 PM
Model Citizen
herr_oberst's Avatar
Yes, carefully pry off the emblem on G50 shift knobs.
Old 12-13-2011, 01:53 PM
Dublinoh's Avatar
Yes thank you...maybe this photo will help the next "knob removing amateur"
Old 12-13-2011, 02:32 PM
Wine User
warner53's Avatar
I know what you will be getting for Xmas...LOL
Old 12-13-2011, 02:38 PM
Dublinoh's Avatar
I don't need anymore thumbs......I do love this site...thanks to our host Pelican
Old 12-13-2011, 02:46 PM
