-   -   cis too (http://forums.pelicanparts.com/porsche-911-technical-forum/71214-cis-too.html)
fly944 06-11-2002 05:39 PM
cis too
Ok guys here goes nothing. I've been dealing with a cold start problem for a while now and am ready to fix the problem. My car 1976 911s is hard to start when cold. It takes a good 30-45 seconds of turning the car over (depending on temp.) to get it to fire, then usually stalls or idles low and slowly comes to life and runs flawlessly. I have already done several searches however just get confused in all the garbage. I would really appreciate any help.
beepbeep 06-11-2002 05:41 PM
Make sure WUR-thingie is working, make sure hoses going to it are tightened and not leaking.
fly944 06-11-2002 05:46 PM
how
ok, how do i check that? all hoses are in place.
john walker's workshop 06-11-2002 06:16 PM
first, as you work the starter, the cold start valve sprays fuel into the intake, and if you have a decent ignition system, the car will fire fairly quickly. this doesn't mean it will continue to run, as all the CS valve does is get it firing. the warmup regulator takes over from there, and keeps the mixture richer for a few minutes until the engine warms up. the sputtering and popping when it's cold usually indicates that the WUR is a bit off and not richening the mixture like it should. i would first look into the cold start system, if you have to crank for 30 seconds before it will even fire. of course the points and plugs, and general tuneup specs need to be in decent order for best results. search "warmup regulator" or "WUR", for info on how to make it run richer.
Hladun 06-11-2002 09:32 PM
Try reversing the two leads to the thermotime switch (on the left cam chain cover).
thrown_hammer 06-12-2002 04:30 AM
There is a small screen inside the in line of the WUR. Take off your fuel lines and make sure it isn't ubstructed. I blasted mine with carb cleaner and lightly blew it out with an air hose.
