excesive road/interior noise roaring/howling
One month ago I finally purchased my dream 82 911sc Slant Nose,now that I've put a few hundred miles on her, she seems to be getting louder and louder every time i drive her. I've had other muscle cars with similar extra wide tires that were not nearly as noisy. I've never owned or rode in an older Porsche before so i don't have a baseline to compare tol, however at 60 mph it exceeds 90 decibels.
What are normal sound levels, should i be concerned that something is worn out like a bearing or transmission, is there anything i can do or check before i open nearly empty wallet?
Thank you in advance for any suggestions
Spencer
Old 10-01-2012, 10:26 AM
Designer King
Paulporsche's Avatar
Check your wheel bearings and if your car has a sound blanket on the firewall. Also check how old your tires are and make sure you have no exhaust leaks.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 10-01-2012, 10:41 AM
tobluforu's Avatar
My R rated tires are loud as hell, does it make the noise when you let off the gas, or is it constant? What about coasting, car out of gear? Try to load the bearings by swerving left and/or right to see if it gets louder.
Old 10-01-2012, 10:49 AM
Spiderman
Jesse16's Avatar
+1 on worn tires, rears in particular. Mine roared noticibly and improved with new. Still overall a loud car but the tire noise is gone. Also my cat bypass increased the noise.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 10-01-2012, 11:02 AM
Thank all of you for the responses, not only am i a porsche newbie, but ive never used a bullitin board' before either. Needless to say after i posted my question i could not figure out how to get back here to check replies. Ill try the suggestions and give you an update.
Thanks again,
Old 10-20-2012, 05:12 PM
