Broke my brake line, how to fix?
Noticed leaking brake fluid from the rear driver wheel and sure enough it was the brake line. I figure the car is old enough I would do all of the lines. Took them off today to ensure they needed replaced, and yep, big ole leak on that driver rear line. So anyway I take them apart, get to the last one, and as I'm loosening it, the metal line going to the brake line breaks right at the male nut. Darn!
So now what? do I need a whole new line or is there a way to cut and extend that line and put the nut back on? I hope I didn't just turn a "simple/cheap" job into a "difficult/expensive" job... |
cycling has-been
our host sells a replacement - not too pricy as long as it's not a 930
73 911T MFI, 76 912E, 77 Turbo Carrera |
PhD on Pending Projects
+1 Just order a new line from our host... that is what I did for the RS build
Drive safe! 1967 - Porsche 912 1981 - Porsche 911 SC 1991 - Porsche 911 C4 Wide-body Cabriolet |
one of my better local parts stores sells straight replacements. a cheapo bender and you can make your own. the bender looks like a pair of pliers with a wheel on it.
take your old threaded fitting with you..i seem to remember two types of non-SAE stuff.
poof! gone |
Fleabit peanut monkey
+1 on vash's comment. However, the lines (at least feeding my front calipers) you buy from the local stores are softer than the Porsche metal line. Not sure if that presents risk but it might. Bring your old line to match fittings.
1981 911SC Targa |
Wer bremst verliert
I believe the Porsche fittings are M10 1mm TP bubble?
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Here:
Yep! Thanks all, I had to call to make sure I got the right one, but I can live with a $20 mistake.
Retired Member
That is what I do. There are a couple of local parts supply outlets that sell various lengths with metric fittings. Bend to suit and install. Simple.
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine. |
cycling has-been
here's a free tip - remove the spring clip from the mount then wiggle the 17 mm fitting back a bit (toward the center line of the car) so you can grab it with a wrench when loosening and tightening the 11 mm fitting
Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 10-22-2012 at 06:36 AM.. |
I'd stick with steel lines. Those look like copper to me.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Swapper and Ruiner
That looks like an easy bend. It's an alloy. Make sure you get the right flare - it's called a bubble flare. I bought the tool and can make them - if you're in Houston or nearby, let me know and we can just make it up in the garage.
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/502929-diy-iroc-rsr-conversion.html http://forums.pelicanparts.com/porsche-911-technical-forum/649179-rsr-ls-conversion.html |
well i ordered from pelican but there was delay delay delay, i guess since they ordered from Germany. I was able to find a line that did the job at Napa. Got everything installed, took it to DMV and got it inspected, and had a great weekend driving.
Great news, thank you for the update!!
