1978 911 Targa A/C add on
I have a 1978 911 SC Targa. Presently the engine (3.0) is being rebuilt, but no A/C. Is this the time to add the A/C, secondly is who offers a dependable and complete A/C unit, third does the dash need reconfiguration, and lastly is it worth it?
I also have a 78SC Targa with no AC. It has never been an issue for me, in the summer I always roll with the top off so AC is really a non issue for me even on the hottest of days. It really depends where you live. I live in NY and the summers get hot but never really that bad, i you live some where in the south or a place where the heat is really bad than that may be a different issue. Where are you located?
I would say its not worth it but that is just me. Look at it this way, you will most likely be looking at around 1.5K for the stuff (or at least that is what I have heard from people who have upgraded to decent working systems) I have no idea if that is all new parts or upgraded existing parts. It has long been known that the AC systems in these cars are only ok at best which is some thing to consider as well. There is also the addition in weight which may not be an issue for you but many would not be happy about that. Think about how often you would use it and if it is worth it for you. I also do not if its as simple as bolting on the compressor and running some tubes so you may want to look in to what it will take. You will not have to modify the dash, i believe the AC controls were traditionally mounted in the center console. Regards Dave |
Guess it depends on where you live as to if you need it. I just took mine out as it didn't work and almost started a fire.
If you have a dire need and $5k+ burning a hole in your pocket then go for it. Vent system will need to be modified. |
Here is some great background info...works exactly as advertised...got mine while in south Florida and have been completely satisfied...the "hurricane fan" is essential.
Porsche 911 Air Conditioning, Porsche 930 Air ConditioningUpgrade Updates,Improvements |
The only actual shortcoming of the factory system is the lack of refrigerant condensing (cooling) capability. You can easily and inexpensively overcome that problem, and improve system relaibility. Just add a trinary pressure switch in the high pressure line at the compressor, use one set of sensor switches to control the compressor clutch on/off cycling and the second switch to control 2 12 volt radiator fans to provide "make-up" airflow through the rear lid condensor when the engine RPM isn't high enough for adequate condensor cooling airflow. |
Jim,
1) You can add AC at any time, engine in or out. The benefit of doing the job with the engine out is bolting on the SC style compressor strut mount to engine console, and if by chance your crank pulley is not a 2 groove you'll need to bolt one on; it is a bit easier to do these 2 tasks engine out of the car but I've done both ways over the years 2) Since EVERYONE (experienced owners) knows the stock system 'out of the box' from the factory was inadequate and not reliable, otherwise you would not find thousands of posts here on Pelican or the Rennlist about AC, you know right off the bat what ever you do will need to be better. Period. The shortest path to that solution if a mixture of the old and new. The old being certain 'used' components that are simply less expensive to source used vs. new. The 'new' components being improvements. If you drop me a PM we can get you down the logical path. 3) Is it worth it? Well you know that is always subjective, an opinion. The question comes down to how hot and humid your climate is and how many days a year you want to drive your car in those situations: is your car a weekend warrior with no other occupants, or is going to be a daily driver. I tend to look at it in these fashions: A) Do you want the car to die before you do, are you going to really drive it as much as possible and enjoy it? B) Engine rebuild $10k+, tranny rebuild $3k+, body and interior fixes $$$$, stereo upgrade $500+, tires, shocks, etc. Spend all that cash and if you don't have a good AC system well ?? So the price to have a comfortable cockpit is priceless! |
In other words, either bring DEEP pockets or don't come. |
Yea, forget the 12v fan idea. That's the real snake oil. Factory could have put fans all over that rear condenser back in 78 but chose not to, and there is a simple reason why.
Besides which in that era Porsche seemed to be turning to Lucas Electric for the blowers/fans used up until about 1990. |
Well unless your goal is to block the flow of air to the engine of course, then mission accomplished. |
I would highly recommend installing an A/C system if you can afford to do so, but it is not cheap if you have none of the parts. You can do it in phases. You will need a bolt-on under dash vent system like on the earlier middies. I did like Griff suggests and put the double belt pulley and bracket on while the engine was out and then collected the remaining parts while I drove the car. The system was well worth the cost as it allowed me to drive my car in Albuquerque year round. Why shouldn't a 911 have a working A/C when even a KIA does? Since I never plan on selling my 911, it is a reasonable cost amortized over many years of enjoyment. The aftermarket Kuehl system installed in my '74 worked much better than the fully functional, freshly serviced R12 sytem in my low mileage '89 Carrera.
The dual Kuehl system that Jim Sims installed on my '74 a few years ago worked great...about 34 degrees at the vents with R134. Kuehl parts worked amazingly well and required no cutting of my car (there is a very good thread here devoted to Jim's install...Jim did an amazing job). Kuehl...Griff Unfortunately, I was hit by another car and mine was totaled. Although it was a pretty bad collision and totaled both cars, it was a front end collision so most of the A/C system was spared. I kept the car around for a year or so and the engine still ran perfectly, and the A/C was still ice cold despite the serious impact. Eventually I pulled the engine, tranny and A/C as donors for another '74. I have installed part of the A/C system in my "new" '74 as well, but have a few parts missing (like the rear wheel well stone guard). Some of the barrier hoses also need replacement. Do you sell replacement parts like these outside of your kits? Also I am on the east coast now, so I am curious if you have a shop that does installs or just sell parts. It is taking me forever to get to this as I work almost all the time these days and would be happy to have a pro finish the remainder. |
Jimbio,
Swing over to the Pelican classifieds here: Porsche 911 Used Parts For Sale & Wanted - Pelican Parts Technical BBS You can do a search (tab is on the right top side of all forum headers) for AC, A/C, air conditioning (all the logical key words) in that forum and look for someone parting out, say a 1978-1983, 911. You want everything they have to offer but the hoses, drier, thermostat and compressor. If you are serious about an ac project we can guide you in more detail. In terms of 'vents' for your year car, you don't want a knee pad vent, rather you want the guts to the ventilation components from the evaporator box to the vents from the 78-83 for example. Flintstone Glad to hear you had a positive experience with our Kuehl products; a kudo now and then does tell us we are doing something positive for our community. Feel free to contact us if you need help with your next project. Best Regards, Griff I don't want no garage queens or weekend warriors in my parking spot. I want my car to die before I do. |
My bad (above)...I didn't realize the '78 didn't still use the kneepad distribution setup (never ridden in one that new except for my '89)...That should make it a lot easier to source.
Engine heat rising through the rear lid condensor AFTER the engine is shut down? Via testing this specific circumstance I have satisfactorilly proven, at least for myself, that high side refrigerant pressures could easily rise high enough to possibly by-pass the o-ring seals, or even as others contend, force refrigerant molecules through the non-barrier hoses due to pressures they are not designed to withstand. So the answer might well be to provide condensor AND engine cooling airflow POST engine shutdown. |
Simply for the sake of redundancy for those, ahhh.. believers of unproven propositions,........... we will go over what is factual, well known in the 911/930 community for many many years, and discussed in thousands of threads through out Pelican, Rennlist and other sources: ....
Did you ever wonder why with the introduction of the 964 in 1989 they decided to use very expensive aluminum tubing from the compressor side lines up to the front of the car? "Rate of permeation". Quote:
Many people complain that they had their systems recharged in the summer and the following season they have lost refrigerant, however their technicians cannot find the source of leaks with either black light & dye or electronic sniffing. This is because of the slow permeation rate (xxx parts per million x given time) through the hoses was the cause and cannot be detected with the dye or sniffer. Quote:
so don't worry about. The reason we suggest to replace the thermostat is simple: A) If you have ever purchased a used 25 year old thermostat that has 36" of 2mm nominal OD soft hardness aluminum tubing filled with a gas, that has been ripped out of a car, stored in a garaged with piles of junk on top, and the shipped to you.... well, you would know better. B) After 25 years of operation: bellows opening and closing, contacts making and breaking .. things get tired. Quote:
Please proceed with designing of your devices and post your pics and results here when your done. |
| All times are GMT -8. The time now is 06:36 AM. |
