Grinding while Braking?
I just noticed that every 5 or 6 times I brake, I get a slight griding/vibration. I can't tell if it's coming from the front or the rear.
I have cross-drilled rotors, I'm quite honestly, I'm not sure if they can be turned or not. It wouldn't be a bearing, would it? Thanks!
Michael '98 Boxster in Ocean Jade Metallic |
I had a slight intermittent vibration coming from my left front which I feared was a bearing but it turned out to be a warped rotor and hung up caliper.
After doing a complete brake overhaul (rotors, pads, caliper rebuild, hoses, and fluid) no more noise!
Doug '81 SC Coupe |
Senior Member
Can also be a rock stuck in-between the dust shield and the rotor.
Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
