Heater control fit question
I need a replacement heater control plastic face for my 79 911.
Will one from a 70 911 fit? Tks |
anybody??
Heater Controls.
I checked the PET for you, but could not come up with a P/N.
Gerry |
I think there are some cosmetic differences and there are a couple different versions of the controls, some with 3 levers and some with 4. Aside from that, I think they should interchange. I've put '73 controls in a '77 before.
I'd have to do a little more research to be certain. JR |
Thanks Gents
sure appreciate your help here |
The controls with two levers on the top row were for cars without A/C, and (I think) was introduced with the center dash vent (1977), but maybe earlier - don't recall right now. I have a 4-lever control in a box if you need any pictures.
the face is part of the whole assembly. it doesn't come off separately.
Control Switch
Might be a bit of a job with the control cables, lights ect....
http://forums.pelicanparts.com/uploa...1351274528.jpg |
Is yours broken or missing?
The mounting tabs were broken on mine, and since these face plates are unavailable, I ended up using black epoxy to fix mine. |
The mounting tabs are broken tks to the PO
Looks like another job for my JB Weld |
| All times are GMT -8. The time now is 01:52 PM. |
