Identifying ports on my fuel tank
Trying to understand the difference between replacement oil tank options. I have seen two sorts, largely the same but some have these two additional connections on the front and wondered what they are for:
Am assuming the main oil return is the connection bottom left (and connects internally to the oil filter), is this for some sort of auxiliary loop?
Old 12-08-2023, 10:06 AM
That's a turbo tank. Regular tanks don't have those two ports.
206 637 4071
Old 12-08-2023, 10:46 AM
I ROC!
mpeastend's Avatar
disregard
Old 12-08-2023, 11:01 AM
Thanks. I'd come to that conclusion (based on no fact, just that I couldn't think what else it could be for).
Not sure why I've got a turbo tank, guess it was replaced at some point.
Any info on how those ports are connected inside, does one go to the filter like the main oil return? Can't find any images showing the film oil flow for a turbo
Old 12-08-2023, 11:39 AM
Wrong Description……..…..
Originally Posted by elrao View Post
Trying to understand the difference between replacement fuel tank options. I have seen two sorts, largely the same but some have these two additional connections on the front and wondered what they are for:
That is your oil tank. Not a fuel tank.
Tony
Old 12-08-2023, 01:46 PM
Tony
Thanks for pointing out the typo, had it correct in the title atleast!
Old 12-08-2023, 11:40 PM
This is the only parts diagram I have found that shows a connection to the front. Is from a sportomatic, implies this is the oil system for that (not a Turbo)
Old 12-09-2023, 04:24 AM
