Alternative to butyl tape
Folks,
Any options other than butyl tape for the gasket between the body and front fenders? I'd (ideally) like to be able to take the fenders off without them being stuck to the butyl. I assume I need some sort of gasket in here to stop rubbing, and seal the gap.
Anyone use anything like neoprene rubber or some sort of "reusable" gasket in there?
Old 12-06-2023, 12:05 PM
Senior Member
Originally Posted by NotStock View Post
Folks,
Why would you want to take fenders off more than once?? If you’re doing a fit just leave the backing paper on the fender side of the tape until you’re ready for permanent fit.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 12-07-2023, 07:42 AM
evan9eleven's Avatar
This may be a dumb question, but is it possible to use single-sided butyl or other closed-cell foam tape for the fenders, or must it be double-sided? I'm going to be doing this job soon myself, and as is obvious, this will be the first time.
1981 911SC restomod "Minerva"
2004 Boxster S
2021 Cayman GTS 4.0 manual "Olive"
2014 Cayenne GTS V8 (wife's lover)
The slope is not slippery; in fact it is entirely frictionless.
Old 12-07-2023, 08:21 AM
I like messing with the car and I take it apart a lot. I want to be able to take it apart and put it back together without having to scrape and replace butyl tape.
That's what I'm thinking. 1/8' neoprene tape. Glue on one side.
Old 12-07-2023, 09:41 AM
Senior Member
I guess as long as you don’t get your car wet you’ll be ok using something other than butyl tape.
Old 12-08-2023, 06:58 AM
Good thing it never rains in Norway then 😁
Double-sided butyl tape it is.
2004 Boxster S
Old 12-08-2023, 07:11 AM
PCA Member since 1988
I use 3M seam sealer. It does not come off easily, but it is very durable.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 12-08-2023, 11:43 PM
