-   -   Dme (http://forums.pelicanparts.com/porsche-911-technical-forum/713294-dme.html)
Discseven 10-25-2012 03:00 PM
Dme
For a 1985 911 Carerra 3.2, there is either no spark or no fuel reaching one cylinder. I'm wondering if it is possible for the DME to be doing this in either case? And is it possible to diagnose a DME to determine if the problem is the DME?
rick-l 10-25-2012 03:03 PM
The DME fires all injectors together. The ignition events are identical for all 6 cylinders and the energy is routed by the distributor.
86 911 Targa 10-25-2012 03:18 PM
No Spark.
Have a look at the disributor/rotor/wires, and all conections.
Good luck,
Gerry
mr 911 10-25-2012 07:05 PM
always carry a spare I say...
DRACO A5OG 10-25-2012 08:21 PM
Check the OHMs on the ref/speed sensor
steely 10-25-2012 09:47 PM
You might consider swapping the plug wire, maybe plug too. Ohm out the injector to make sure it isn't open, or check/swap it to make sure it isn't clogged.
And like Gerry suggests, checking the connections. Check the large bundle of injector returns (ground wires) which are tied to the same point on the intake. Look inside of the distributor. It wouldn't be your DME if the other 5 are working.
DRACO A5OG 10-25-2012 10:11 PM
To answer your question, it can be diagnosed. With a strong magnifying glass check the solder joints for cracks and if cracked re-flow.
You do this at your own risk.
Discseven 10-26-2012 12:04 AM
Thanks for all the good input! I'll post what I discover.
gamin 10-26-2012 07:11 AM
Doesn't sound like the dme RELAY as differentiated from the dme which would be the box under the left seat. I would continue the trouble shooting procedures as above.
