Door hinges with excessive play
Hi all
My passenger door hinges were shot, there is a lot of up, down play, I replaced the door pins, Yea that will solve it..... Wrong. the play is still there, now on further investigation I notice that it is the door portion that the pin slips into that's worn away, The two bits on the body that the pin slips through look fine. Now I cannot see any way of replacing the door hinge part connected to the door itself. Is there a way to replace those? Do you need to get a bush inserted in there? Anyone else have this problem? Why passenger side? and not drivers? Was it left without grease for too long? Thanks in advance Jakes
If you want to run with the big dogs, you can't pee like a puppy!!! 92 Rover Metro 1.1 (54 manly horsepower) - Dont knock it it does 60 mpg!!! 81sc / 3.2 litre transplant (Broken BIG Time ) SCWDP deserter - HP junkie wannabe |
Jakes - there are 2 bushings used with 1 pin for each hinge. Check with Pelican or local dealer for parts. Fitment is very tight on installation - bushings must be lightly machined on the inside for proper fit.
Mike - PBG, FL '14 958 Cayenne GTS '05 997 C2 - SOLD '79 911 SC Widebody PCA, NASA, PBOC - SOLD 2004 NASA-SE GTS4 Champ, 2005 + 2007 NASA-SE GTS3 |
Not Quite Banned
Mike is right - you need bushings.
Thomas Owen 1972 911T 1972 911S |
