Intermittent Seatbelt Light
Halfway there.....
I have isolated the intermittent flashing seatbelt warning light to occur only when the wipers are on !!!! It works normally on startup etc.
1987 911
This is one of the last electrical issues to sort out. Any ideas??
Old 04-19-2012, 04:00 PM
turbo23dog's Avatar
I had the weird seat belt warning light blink on and off too. My research said it was a failing alternator. I replaced with a reman unit and no longer have the problem.
Rich Franco
Northern Virginia
1980 911 SC Targa
Old 04-20-2012, 05:30 PM
toddadale's Avatar
Same issue
Did you find the issue? My beat belt goes on when I turn on my wipers too
If everything seems under control, you're just not going fast enough.
Mario Andretti
Old 10-25-2012, 10:23 PM
Sugar Scoops Rule :)
dave 911's Avatar
Mine goes on for a second or two when I hit a bump, but very intermittently -- maybe once per drive. I've attributed to a short in the wire somewhere but haven't been able to find it yet. It's been doing it for years, both before and after I replaced my alternator.
Maybe one of the guru's here will respond with a good place to hunt
Dave
_______________________________________________
'76 911S Targa
'62 VW Type 1 Sunroof
'73 914 2.0 (1st Porsche, gone long ago but not forgotton)
Old 10-26-2012, 04:59 AM
Counterclockwise?
Solved mine as well. Do your headlights flicker sometimes?
Rod
1986 Carrera
2001 996TT
Old 10-26-2012, 07:54 AM
