pkfrdh's Avatar
Question Original German rubber undercoating...any source for it?
Is there a source for the original German light colored rubber undercoating? If so...where and how much? Is it available in spray cans?
Thanks for any help?
JGL
Old 06-12-2002, 04:44 AM
T Bird's Avatar
Try Wurth SKS Stoneguard. It matches Porsche's OEM body schutz. The recommended application method is to spray it on with a special Wurth SKS gun. It can be brushed on as well, but the texture will not be correct.
Click on:
http://www.carcareonline.com/mfgr_frame.html
The click on "Wurth" and slide down to "SKS Stone Guard."
Good luck.
John
1972 911T Coupe
PCA- Potomac Region
Old 06-12-2002, 06:29 AM
Early_S_Man's Avatar
Porsche Crest
The Wurth product is probably satisfactory ... but Valvoline Tectyl was the OEM coating ...
http://www.google.com/search?as_q=valvoline+tectyl&num=100&hl=en&ie=UTF8&oe=UTF8&btnG=Google+Search&as_epq=&as_oq=&as_eq=&lr=&as_ft=i&as_filetype=&as_qdr=all&as_occt=any&as_dt=i&as_sitesearch=&safe=images
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 06-12-2002, 07:01 AM
Senior Member
Hello
Porsche used different products but I never had seen rubberized undercoatings from the factory.
Maybe you talk about the Plastisol Undercoat ?
BTW finding the correct Tectyl Product follow that links:
http://www.tectyl.com/bulletinview.taf?bulletinid=15
http://www.tectyl.com/categories.taf?ProductLineID=1&CategoryID=1
Most come in big packages for industrial use.
Grüsse
Old 06-12-2002, 09:15 PM
