82 SC cam overlap
I'm installing a chain tensioner update in a 82 SC. the camshaft overlap is .74 mm. This does not seem correct. I found a TSB showing 80-81 at 1.40 to 1.70 but does not have 1982. Do you have the 1982 overlap spec. Thanks.
Thats also the 82/83 specs.
78/79 is .9 to 1.1, all on the same cam shafts Bruce |
Thanks Bruce. Eyeballing the cams and they were not straight up, so I check the overlap. I used to have a Bently but loaned it out. Thanks again
| All times are GMT -8. The time now is 03:20 PM. |
