Wer bremst verliert
Freeware wiring diagram software?
I am rewiring the race car and want to map out all the circuits to simplify troubleshooting later. I started doing everything on Powerpoint and then on Visio but its a true PIA. None of them do well with revisions to the circuits. I checked the usual download sites but couldnt find any decent trial or freeware programs for Auto applications. I will only use it once or twice so the price of the higher-end programs seems impractical.
Any suggestions? Thanks
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
Cigars and 911's -- Smile
http://www.freedownloadmanager.org/downloads/wiring_diagrams_info/
You should be able to find something free there, or at least a 30 day version.
[GruppeB # 978] 1978 911 SC ROW (Pure Euro, no DOT or EPA work done..) 1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket) 2001 Audi - A6 Quattro 4.2L-V8 (love the growl) 2014 Honda Odyssey for the soccer-team/accessories |
Less brakes, more gas!
Wiring diagrams are always a PITA. You should try doing them in ACAD12!! I think Visio would be your best bet for a COTS solution. At least there the wires are linked to the start and end points. I always had trouble getting teh colors to look right and finally gave up and used text instead. Let us know how it works out...
Best regards, Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
+1 Visio is straight foward to use. I have used it for process flow daigrams and P&ID's. Much easier than with AutoCAD, which I use for everything else.
Chris 2 1977 911S Targas Gone but not forgotten 1985 Carrera Targa Current Toy |
R&D guy
Location: the border between the states of inebriation & confusion
I agree that Visio is a good tool for this, and would be far easier than a standard 2D CAD package, but there is another option, and it's free:
A PCB (printed circuit board) layout tool. My suggestion would be to use the one available as a free download from ExpressPCB. http://www.expresspcb.com/ExpressPCBHtm/Free_cad_software.htm The advantage to this is the built-in component library that includes connectors & other related components. One can easily use pads as junction locations, and modify standard component representations to suit the application. One can also use the lead widths to represent different wire gages. Another alternative, from the same supplier, is the ExpressSCH tool used for drawing schematic diagrams. In fact, ExpressPCB and ExpressSCH allow the schematic & PCB layout files to be linked. Last edited by dw1; 06-13-2008 at 01:19 PM.. |
Wer bremst verliert
Thanks guys. I dont have a copy of visio on my home laptop so I've been playing with eDraw (runs soo slow!) and now with Express PCB. The latter seems to be more technical but more accurate and faster to use so I'll go with that for now.
Thanks!
Wer bremst verliert
Here's a draft...only issue with Express is it only saves to its proprietary format or prints to XPS, which is useless. Here's an image from a screenprint...anyone have a good XPS-to-JPG converter?
R&D guy
You shouldn't need a converter.
Are you looking to put the diagram into another document, or is printing to .pdf ok? If .pdf is ok, then you may want to consider one of the following: Blubeam pdf revu (30 day free trial) Scansoft pdf create Adobe Acrobat writer ($$$) If you need a jpeg file: The ExpressSCH software does have the option: "File > Export schematic to bitmap" The resultant bitmap (.bmp) file can be either used directly, or opened in the "Paint" application that is include with Windows, and then saved as a .jpg. The limitation on the "export to bitmap" is 300 dpi, but that seems ok. There is also the "Edit > copy schematic diagram to clipboard" option in ExpressSCH if you want to cut & paste the diagram directly into another document, e.g. an MS Word document. Be careful, however, as bitmaps cut & pasted directly into documents tend to make for much larger files than the MS Word function "Insert > Picture > from file" using jpeg files. |
Wer bremst verliert
Got it, thanks for that!
I would rather be driving
here are two that I use. They are more for circuit layout but they can be used for wiring diagrams.
Express PCB - two components for layout and PCB design. http://www.expresspcb.com/ExpressPCBHtm/Download.htm TI Tina http://focus.ti.com/docs/toolsw/folders/print/tina-ti.html
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Wer bremst verliert
Thanks Jamie. I used ExpressPCB Schematics for the one above.
Express tools
Express PCB and ExpressSCH circuit diagram creator tools was very useful. Thanks!
