Where to purchase fog lamp switch bulb?
Just purchased a great switch from Andrew15 (Thanks Andrew) to wire into the fan on a newly installed ER front cooler. The bulb that the switch calls for is a " Form W ". Anyone have any idea where to purchase this?
Thanks For The Help, Dana Specifications On-off switch (NO) No. 0340006012 Load max. 100 W / 24 V Attachment with knurled nut M 12x1 Installation Ø 12,5 mm, wall thickness up to 6 mm Connection Tab connectors or screw terminals For rear fog light Safety gear knob with black soft PVC and control lamp Green lens mounted, red and yellow lens enclosed 12-V bulb installed Bulb (Form W) No. 1987302208 (12V 1.2W) 1987302504 (24V 1.2W) Illustration Circuit diagram |
FLAPS or Radio Shack
+1 flaps, it is a standard, readily available bulb
Duh. Should have thought of that. Just never heard of that size.
Thanks. |
Just take the bulb out and take it with you down to your FLAPS. They should have them.
| All times are GMT -8. The time now is 02:05 AM. |
