Access to fog light switch
Hi gang,
I am installing a factory Fog light switch in the dash of my 1975 S. I was hoping I could have easily accessed the switch through the hole were the radio goes. Unfortunately you cannot gain access through that route. Do you access to fog light switch through the front of the car? Is the only way to access the fog light switch through the front of the car, by removing the front blower assembly and the associated piping. Thanks |
Sorry to write: YES :-( Everthing basically needs to be pull out to get your hands in there to unscrew and disconnect the wires, mark them carefully before disconnecting.
Try to get While you are in there items done. Before putting everything make sure it functions properly and not interefere with other components. my system is hooked up to the central door lock, Ask me how I know :-( |
Thanks.
I feared that |
It's no big deal just time consuming. If you need any help PM me :D
| All times are GMT -8. The time now is 05:10 PM. |
