Racetek
racetek's Avatar
Correct clutch plate
I have a sachs aluminium pressure plate which came with its original clutch plate. Both seem to have minimal usage but the clutch plate has been sitting for a while in storage and has some rust in the spring plates which have distorted the plate.
I read in another post that the clutch plate for an aluminium PP is thinner than a standard plate. I see that normal clutch plates are advertised as having 10mm thickness.
My question is, would these work with my ali PP and if not, where could I get a thinner clutch plate.
Old 10-30-2012, 01:54 AM
Deadeye's Avatar
I don't think the plate is different. Pretty sure the spring center disc is the proper one to use w/ the light weight clutch. My book says 7mm minimum disc thickness on the wear area and new is about 10mm
Old 10-30-2012, 05:27 AM
