-   -   windshield caved in doing 110 (http://forums.pelicanparts.com/porsche-911-technical-forum/714088-windshield-caved-doing-110-a.html)
dfink 10-30-2012 10:45 AM
SCCA Time trial my lexan windshield caved in on me. Gets your attention.
<iframe width="420" height="315" src="http://www.youtube.com/embed/uUFxGxlkJRs" frameborder="0" allowfullscreen></iframe>
DRACO A5OG 10-30-2012 11:06 AM
Whoa
OsoMoore 10-30-2012 11:27 AM
At 24 seconds in the video - did you have it sealed properly? I'm glad it didn't lead to disaster.
Flat Six 10-30-2012 11:28 AM
Holy cr@p!! Bet that got your attention!
Grady Clay 10-30-2012 02:11 PM
Perhaps this may tell you why Porsche uses a standard glass windshield (or even a thin glass version).
I have been 220+ mph twice a lap for 12 and 24 hours (935K3) and never a failure.
Let’s see:
Weight savings from a Lexan windshield – a few milliseconds per lap.
Time spent replacing Lexan windshield – down several laps.
Time gained from seeing where you are going (at only 110 mph) – priceless.
Enough said.
Best,
Grady
winders 10-30-2012 02:19 PM
Grady,
All that needs to be done is to use the appropriate thickness (read 1/4") polycarbonate windshield. That thing looked way too thin.
Scott
Grady Clay 10-30-2012 02:44 PM
Scott,
I guess above I was being a bit scurrilous.
My point should have been that the best vision possible makes for the fastest lap times.
I’m probably a ‘poster boy’ for vision vs. lap times.
With my former myopia, I worked hard for the best vision possible while racing (in the ‘60s, ‘70s & ‘80s).
Only recently with cornea implants have I realized how much better vision I could have had and how much faster (and safer) I could have driven.
Sorta the difference between a 935 brute and a 997Cup.
So … my recommendation is to have the best vision possible – a few grams of weight be damned.
Best,
Grady
Dantilla 10-30-2012 02:54 PM
One of the fast guys around here couldn't stand the distortion caused by the Lexan windshield flexing at speed.
Went back to glass.
dfink 01-29-2013 03:32 AM
I am pretty sure the issue on this was of my own doing. I used a new window seal and forgot to put a cord in to serve as a lock. Normally there is a metal lock piece "trim" that helps lock the window in. A piece of rubber cord normally used to hold window screen in will work as well. I forgot that step. The winshield didn't cave in as much as the rubber turned in because it wasn't expanded and locked. That then allowed the lexan to flex in.
redstrosekNic 01-29-2013 04:19 AM
Whoa!
MrBonus 01-29-2013 04:33 AM
Finally, a pragmatic solution to our temperamental and poorly-functioning air conditioning systems.
redturbo911 01-29-2013 05:08 AM
Wow thats crazy. Good thing you kept cool. Glad it worked out for you and nothing major happened.
dgmark 01-29-2013 05:20 AM
After replacing 2 glass windshields in two years I switched to lexan, no problums if its installed correctly and cleaned properly
GeorgeK 01-29-2013 05:23 AM
Lucky it did not back into your face, or throat area...
at 110 mph.
wayner 01-29-2013 06:32 AM
Search youTube for "miata crash"
Mid way through the video a guy loses his steering wheel.
Aside from this and that incident, you guys amaze me with your composure when things go wrong. I might have jumped out ;-)
mpetry 01-29-2013 07:12 AM
I've got a video of a tire failure on the banking at Daytona - doing about 160 in a GT3 Cup. The car spins around and the windshield blows out - it is like a bomb going off. Not sure if my website will stream it but here is.
http://petry.org/markp/DaytonaGT3RS.wmv
Not something I'd like to have happen to me. Might need a new driver's seat as well.
Deadeye 01-29-2013 01:06 PM
Did you have any clips installed? I have 6 aluminum clips that prevent this kind of blow out.
bavaria911 01-29-2013 06:50 PM
Did you ever think of a safety issue there?
Jerome74911S 01-30-2013 07:04 AM
Best,
Grady
Amen to that.
