tailwind22's Avatar
Help Me Diagnose Low Oil Pressure in a 930
Moved from the 930 forum due to lack of repsonse. Trying to systematically work through a low oil pressure issue in a 1978 930 highly modified motor with unknown miles (leakdown performed by a reputable Porsche only shop showed rates of#1-7%, #2-5%, #3-10%, #4-6%, #5-8% and #6-6%. Pressure when warmed to 180 degrees is 3 to 3.1 bar @5000 rpm. These are consistent readings before and after 1) changing out the oil pressure sender and 2) swapping out the guage from my 89 Carrera (reads a consistent 4.5 bars on that motor) so I know it is not a guage or sender issue. No rattling or knocking is audible. I was going to go the cam line reducer route but that really seems like making excuses for low oil pressure. I will be cutting the oil filter in the next couple of days to see if there are any tell tale signs of metal particles. I would appreciate educated opinions on the situation. Thanks.
Old 11-01-2012, 05:44 AM
304065's Avatar
Have a look here:
Ultimate Oil Pressure Relief Valve Thread
Have you checked the pistons and springs?
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 11-01-2012, 06:30 AM
kodioneill's Avatar
45 psi isn't that bad. My Carrera is 3.5 when warm my sc is 4.0.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 11-01-2012, 06:34 AM
twistoffat's Avatar
I´m no expert on 930 and their turbos but I read an interesting thread on a German site recently about low pressure on a late 70´s Turbo. Consensus was that 3 bar was not that uncommon but shouldn´t go below that and some had mentioned rear fed oil lines to reduce resistance to centrifugal forces like on racing cars could led to lower oil pressure. Others started going on about oil viscosity on Turbos having an effect on oil pressure up to 1 bar. I´m sure somebody here will chime in maybe to confirm this or possibly to say its incorrect.
Old 11-01-2012, 06:44 AM
tailwind22's Avatar
This is interesting...btw, looking at your avatar I assume you are a road cyclist. My passion also, besides cars.
Old 11-01-2012, 07:01 AM
tailwind22's Avatar
Originally Posted by 304065 View Post
Have a look here:
I did a quick look at the article a week or so ago. I am rereading and will dissamble and take a look at spring and piston. Could be something here.
Old 11-01-2012, 07:07 AM
twistoffat's Avatar
I am indeed and have the scars to prove it.
Old 11-01-2012, 07:29 AM
Lower pressures on pre-78 930's are normal; they have the same oil pumps as the N/A cars.
78-up 930's use the later 930 pump (which, if the figures I've read are to be believed, pump the most oil of any pump the factory used - the later pumps apparently focus on increasing the scavenge, not the supply, side) make more pressure, in my experience.
I have a '78 930/60 motor in a car with a numbered pressure gauge; for the last 7 years/30,000 miles it has read 120 PSI on cold start, dropping quickly to 100PSI, hot it runs 25-30PSI idle, makes 60PSI at 2000 RPM, and reads ~80 PSI anything over that.
When it started behaving differently recently, I swapped the gauge, replaced the sender (which rattles gently when shaken) and had the pressure relief checked. Haven't driven it yet...
'77 S with '78 930 power and a few other things.
Old 11-01-2012, 08:17 AM
