Deceleration valve?
I'm trying to identify a valve that controls the manifold vacuum in a '79 SC. The deceleration valve is supposed to slow down the vacuum enough to keep the idle from dropping (from a high RPM) below a point where it stalls. Is this the valve?
1 Attachment(s)
Sorry, the image didn't work the first time. I'll try again:
That's it! I always assumed it was there to keep the engine speed from dropping too fast when one lifts the throttle and dumping a bunch of unburned gasoline into the exhaust. I think it's main purpose is emissions control. Jim
Exactly, Jim!
It's another annoying little part, that is easily disabled by removing and pluging the vacuum hose that connects to it. |
Thanks guys!
I can see the adjustment on top of the valve. But, how do you determine the correct setting? |
Do a search; I seem to recall John Walker explaining the adjustment sometime in the past. Jim
| All times are GMT -8. The time now is 07:41 AM. |
