Recreational Mechanic
Nickshu's Avatar
Those who have removed A/C - How did you plug these holes?
Looking for ideas on how to plug these two holes for the auxillary blower on the front condenser. I am in the process of removing 100% of the A/C parts from the car, removed the compressor years ago, just now getting around to removing the rest.
If you have photos of what you did, please post/share. I really am not interested in welding in/painting. I plan to keep all the A/C parts in a box so that they could be reinstalled if a future owner desires to do so. Thanks!!
Current fun: 2004 911 GT3 - Trailered track only
Current Dailys: 2019 Ford F-150 Raptor / 2015 Volvo S60 Polestar / 2019 VW Golf R 6MT
Past fun: 2003 911 Carrera 2 Coupe (SOLD) / 1982 911SC Coupe (SOLD to a fellow Pelican) / 2005 Lotus Elise S/C (SOLD) / 1964 Corvair Spyder Convertible (SOLD)
Old 11-01-2012, 06:11 PM
Member 911 Anonymous
DRACO A5OG's Avatar
JB weld??? & piece of ABS plastic???
'85 Carrera Targa
PCA/POC
Old 11-01-2012, 06:15 PM
Nickshu's Avatar
Good idea for the top one. That one is difficult b/c it's not a flat surface, it has a curve in the middle of the square.
The bottom one is pretty easy because it's flat. I can cut a piece of sheet metal, seal with silicone or weatherstrip non-hardening "clay" stuff and screw into place....this one is flat and there are already screw holes.
Old 11-01-2012, 06:24 PM
DRACO A5OG's Avatar
True, it you make sections and jb weld them together, after that spray paint both???
'85 Carrera Targa
PCA/POC
Old 11-01-2012, 06:26 PM
I made an 1/8 thk aluminum plate for the bottom hole. I have a 2.5 dia. hose going from the front hole to the evap blower box for fresh air, for the center AC vents. Works great.
82 sc
Old 11-01-2012, 06:36 PM
Nickshu's Avatar
82 sc
Hey that's a great idea. I am doing the same, keeping the evap blower box (took it apart and removed the evaporator, put back together to reinstall w/ the blower only). Nice to have fresh air via those front vents for warm days or track days.
How did you connect the hose to the front hole?
Old 11-01-2012, 06:45 PM
I used a 8 inch wide Craftsman floor suction piece, then cut it to the right length, to snap into that hole, I put two side pieces of rubber on the sides, to seal it.
I can take some good pictures tomorrow, then post them.
I also made an aluminum smuggler box cover, with a hole for the vacuum hose.
Old 11-01-2012, 07:04 PM
DRACO A5OG's Avatar
Nice
'85 Carrera Targa
PCA/POC
Old 11-01-2012, 07:05 PM
SiberianDVM's Avatar
Thin aluminum riveted and siliconed to the front hole; NACA duct and hose from the bottom hole to the evaporator blower (with evaporator removed) for fresh air.
2009 Porsche Cayenne Turbo S; 1999 E36 M3 Coupe; 1989 Toyota Supra ChumpCar; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project
Old 11-02-2012, 03:30 AM
PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
I made some plates from aluminum to cover them. Easy to make yourself at home.
Old 11-02-2012, 04:34 AM
Garage Queen
PorscheGAL's Avatar
I used Dynamat. This is the underside of the car. I also covered the hole from the inside.
Stephanie
My minions:'86 911 Targa 3.4, '87 930, '05 Lotus Elise,
'19 Audi RS3, '13 Focus ST, '16 Focus RS
Old 11-02-2012, 05:02 AM
68Sporto
MrJTP's Avatar
While the '68 was in the shop getting rid of rust damage I had the holes welded shut.
Tony
Porsche owner since 1967
1998 Boxster
1968 911 Sportomatic project
Old 11-02-2012, 06:15 AM
Send a message via AIM to P-Dawger
Cut sheet metal, tack in place, Wurth seam sealer, paint...
Parker D
Old 11-02-2012, 09:25 AM
A few pics of my setup, I got the idea from the above post, thanks! It works great.
I am going to make the same setup for my friends 80 sc
My evap is removed, and I blocked off the hole into the blower box, from the tunnel.
That is my stereo amp, on the smuggler box lid.
82sc
Jeff
Old 11-02-2012, 12:58 PM
Nickshu's Avatar
Here's what I ended up doing. Simple. Cut and bent aluminum pieces, sealed with silicone, and held in place with stainless steel sheet metal screws. Ready to go!
Old 11-09-2012, 06:35 PM
DRACO A5OG's Avatar
Well, there you go
'85 Carrera Targa
PCA/POC
Old 11-09-2012, 07:04 PM
Danny_Ocean's Avatar
Y'all with the vacuum cleaner parts might want to install a screen over the opening. You're turning your car into a very expensive shop vac/bug sucker and/or leaf mulcher.
Old 11-09-2012, 07:22 PM
cycling has-been
bkreigsr's Avatar
some scrap aluminum, neoprene gasket, sheet metal screws in original holes, and some pop rivets.
Bill K
Old 11-12-2012, 04:47 AM
Je Ne Sais Quoi = Targa
Mikey83835's Avatar
Anyone know if these plates are commercially available?
'74 Targa lightweight widebody, 3.6 motor, big bars, Speedlines, Sold 2018,
'81 SC Targa with 3.2 spoilers, Webers, SSIs, 7&8X16 Fuchs, 911R style exhaust,
Had a '71 911S Targa in the 80's, miss it,
Had a '61 Roadster in the 70's, miss it also,
Old 11-11-2013, 08:31 PM
