She no like-a cool weather start up
Now that the blast furnace summer is over in TX, I noticed that my 87 3.2 carrera starts right up and immediately goes to full stall then bumps up on RPM's and back to stall, then stall. I have to start it again and keep pumping the gas peddle a bit until it catches and then it will begin to idle fine. Starts right up any time after that until it sits overnight again.
So far I have: Cleaned the ICV Replaced my Main Montronic Relay under the seat with my spare Still does it....any other thoughts to try? Thanks |
Member 911 Anonymous
Vacuum leak?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Hummm..didn't think of that one. Well, I'll check on that also. Anyone know of a Motronic troubleshooting guide for conditions like this?
Thanks all |
Ed 1973.5 T |
Thank you!
After she is warmed up to 194F or close, remove the oil cap. If the idle drops that is good, if not then you definitely have a vacuum leak.
If she dies, then you have a massive leak somewheres.
