-   -   What's a reasonable rim runout limit? (http://forums.pelicanparts.com/porsche-911-technical-forum/714610-whats-reasonable-rim-runout-limit.html)
gsxrken 11-02-2012 05:30 PM
I just got a Starrett dial indicator and, since the rear of the 930 is on jack stands anyway, decided to try it out on my rear rims. I placed the gauge plunger out as far as i could on the rim near the tire
The RH rim varied from 0 to -.015 and then to +.005. So a total swing of .020.
The LH side was better; it went from zero to -.012 and back. So total of .012.
I intend to measure the fronts too, but I am interested in what the spec is.
I understand that I am measuring total "installed runout" (my words) and that the observed runout might not be all rim related.
What's the outside limit I should be looking for? When is it noticeable in a vibration or wobble?
gsxrken 11-04-2012 01:26 PM
Ttt
porsche930dude 11-04-2012 03:09 PM
if you need a dial indicator to see the runout than its not a problem
swade 11-04-2012 04:35 PM
According to the Technical Specifications book 78-81 930:
Max permissable radial runout for steel rims 1.25mm
Max permissable radial runout for alloy rims 1.0mm
Max permissable lateral runout for steel rims 1.25mm
Max permissable lateral runout for alloy rims 0.80mm
Max permissable radial and lateral runout for rim + tire 1.50mm
Great little books
E Sully 11-04-2012 04:47 PM
HUNTER Measuring the wheel's runout
gsxrken 11-04-2012 05:00 PM
Thanks for the specs and the link. Looking for that Tech Specs printing now.
Cheers.
DennisMenace 11-03-2025 04:15 AM
Hi guys, I just measured the lateral runout of my front right hub assembly after changing the bearing races and wheel bearings. 0.08 mm seems a bit much to me. What is your take? Unfortunately the car won’t be back on the road until spring since it is undergoing several projects..
https://youtube.com/shorts/aJUw84VLK6k?si=sB-Nvwf09SFC21me
Car is a 1985 Carrera 3.2
PeteKz 11-04-2025 12:22 AM
That's about .003". Fuhgedaboudit.
