Stuck in 4th gear! HELP!!
MY Brother in Law is in town for the holidays and wanted to drive my 71 around the block. I agreed and rode along. There was no fast driving or heavy throttle, but he was fighting the gears a bit. We stopped he put it in first turn a corner and shifted to fourth. At that point it is now stuck in fourth. Clutch works fine but it is solidly stuck in fourth. I have checked the coupler and all is well there. Also fluid is clear and full. Any trouble shooting tips? This is a 71 2.2 with the original trans. By the way it has only been on the road for maybe 500 miles after a rebuild so not a nice Christmas present!
thanks for any advise / tips.
Old 12-23-2012, 03:42 PM
Can you get it moving while in fourth (engine running, using clutch)? Get it up to speed and with or without clutch, slip it out of gear?
Paul
Paul
'87 Carrera cab; '19 Ford Flex for the Dane and Lab; '17 Tacoma for truck stuff.
'96 993 cab (gone, oops); '82 SC (gone)
Old 12-23-2012, 03:47 PM
i think id pull off the shifter and see if something got jammed up there
Old 12-23-2012, 03:48 PM
I did get it up to speed and still stuck. The clutch does work. Disconnected the rod from the coupler and can't get the gear to change there either.
Old 12-23-2012, 04:13 PM
Were all the transmission detents installed properly after the rebuild?
Had a similar problem with my 74.
94 turbo 3.6
74 carrera RS race car
05 denali XL
"We are here to laugh at the odds and live our lives so well that Death will tremble to take us." Charles Bukowski
Old 12-23-2012, 05:53 PM
I believe they were... how did you resolve this or how can I check?
Old 12-23-2012, 06:32 PM
Unfortunatly cleal you have to drop engine and transmission and take apart.
Probably not what you want to hear, but that is what i had to do.
Other Pelicans may have some advice, but our race shop mechanic is a 30 year Porsche wrench and we had no easy fix.
94 turbo 3.6
05 denali XL
Old 12-23-2012, 06:39 PM
Definately not what I wanted to hear. Been driving around and hard driving with no issues, now stuck
Old 12-23-2012, 07:03 PM
I drove mine for several hundred miles on track before it got stuck.
The transmission actually gets stuck in 2 gears simultaneously but the symptom is feeling as if stuck in 4th.
Rocking the car forward and back may dislodge but you will still have the initial problem, or if on lift rotate the rear tires back and forth. Another person must be in car to bump the shifter to neutral.
My clutch also was unaffected.
Best of luck and i really hope you resolve your problem.
God, i love these cars!...........most of the time.
94 turbo 3.6
05 denali XL
Old 12-23-2012, 07:33 PM
I pulled the guide fork plate and was able to easily get the rods lined up. Problem solved! Not sure how it got out, but hopefully it won't happen again.
Old 12-24-2012, 10:12 AM
