-   -   78 SC Engine/Transmission Seperation problem (http://forums.pelicanparts.com/porsche-911-technical-forum/714883-78-sc-engine-transmission-seperation-problem.html)
NotaFastM 11-04-2012 12:01 PM
Hello All,
Purchased a 78 SC recently. The car had been sitting for a few years, I have removed the engine for rebuild from the car but seem to have something hanging up to remove the the transmission from the engine. I have removed all four bolts from the engine, also the starter is removed. I have been following Wayne's book and Bentley to the "T". I did not remove the clutch arm from the bottom of the transmission. I suspect this it the problem??
Any help appreciated! My first rebuild so I will be looking for help a lot!
Thanks in advancehttp://forums.pelicanparts.com/uploa...1352059285.jpg
rattlsnak 11-04-2012 02:59 PM
yes, you can either take the arm off, or overcenter the spring mechanism and it will slide right off.
lindy 911 11-04-2012 03:38 PM
Take the circlip of the small clutch arm and slide it off. The throwout fork is holding the tranaxle from coming off.
