911S Steel Brakes?
Did the 77 911 "S" ever come with steel brakes? Mine has steel, they look like regular M calipers t me, but perhaps I am wrong?
I am fairly certain that they are just "M" brakes. If anyone knows any different, please let me know. I have searched and not found anything. Thanks for any help. |
I would rather be driving
Yes. Should be steel. 3.5" spacing, "A" calipers.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
RETIRED
Not to say that someone couldn't have swapped them out....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Thanks for the replies. Yes it they could have been swapped, especially considering the value.
They are 3.5 spacing. Would they be "early A" calipers? Are they as good as Carrera calipers? Thanks again. |
The SC and Carrera calipers are essentially the same...except the Carrera caliper has a spacer to give it a wider throat to accommodate the thicker Carrera rotor.
Tony G 2000 Boxster S |
Not all S cars had S brakes. By 1977, the turbo still used them but the S and a Carrera 3.0 did not.
JR |
Thanks to all who replied. I will keep them for a while. Concentrate on cooling.
