Newbie first winter storage.
Well, had to store the 911 for winter : (
1-did an oil and filter change a couple of weeks ago. 2-filled with gas. 3-added stabilizer and let the motor run for 10min. 4-unplugged the battery. 5-pressured the tires to 40. anything else I should do? Can I leave the battery connected to the car while using a charger (battery tender plus), so the alarm and the lojack can keep working? Should I leave the handbreak off? and finally, what about oil, should I fill it to the max? any feedback will be appreciated : ) Last edited by samourai71; 11-02-2012 at 12:53 PM.. |
87 - 911
I change the oil and filter in the fall, best to do just prior to storage so it sits with minimal contaminants in the oil.
Did you take it for a drive after adding stabl to the fuel tank ? |
87 - 911
Oh, and I leave the hand brake off
I've been pondering winter storage a bit, too. Hoping to drive the car at least once or twice a month if it's dry. All of the threads on ethanol are creeping me out. Is it better to keep the tank full or closer to empty with fuel stabilizer?
Also, I've read the nasty posts where mice make a nice home in the fan. Is it bad policy to just start the car and let it idle for 10 minutes? I used to do that with my motos while I shoveled snow, just to keep things circulating, but I could see an argument that short runs might do more damage?
Porsche Nerd 1976 Targa 2012 VW TDi SportWagen 2012 Volvo C30 Pittsburgh, PA |
I put Stabil in the tank, take her for a short drive to mix the contents, put her into the Carcoon (which has a battery tender) and start her say.... five and half months later. Up until now she's always fired up like I drove her the day before. This has been the pattern for five winters. The ethanol question is of some importance however, I try to fill with Chevron 94 before bedtime since around here, it is the only ethanol free fuel that I know of but occasionally I've had to lay her up on ethanol blend....yuck. Cheers
Reiver
If you are storing the car for an extended period then you need to jump thru hoops (1+ years)..if for the winter months what you did is more than enough.
I work overseas and usually leave my cars for 6 months at a whack...park, stabil, battery and that's it. Never had an issue. |
Detached Member
I live in SoCal so no storage. Can't you at least start the car and run it up to temps once a week, even if you don't drive it?
Hugh |
Reiver
I routinely store for 5-6 winter months. Air up the tires, fill the tank, disconnect the battery and hook it to a tender. Never had a problem. Some say that stabil does more harm than good.
'03 Boxster, '14 Armada,'13 Cayenne, 89 Targa, 05 MB 350SLK, Fuji Altimira 1.1, Trek Madone 6.5, Litespeed Ultimate, BMC TT bike, Merlin ExtraLight |
If your car is pre-galvanized, maybe a good idea to park it on a piece of plastic to prevent condensation. And if it has carbs, disconnect the fuel line and let the carb run dry after you park it (prevent varnish deposits). (I do that with my old BMW, I assume same holds for old 911s.)
Maybe steel will or aluminum foil in the tailpipe to discourage mice. |
Matt Mariani @the_r_institute Authorized Retailer FIKSE Wheels Mod Italian Wheels Maxilite classic wheels |
Designer King
You can leave the battery connected while using the tender.
BTW I'm not a big fan of ethanol either but I have to say that I've been using Sunoco (now Petrocan) Ultra 94, which has 10% ethanol for 20 years in my engine. I don't know how long it's had ethanol but it seems like it's always been there. AFA I know I haven't had any problems caused by ethanol or water in the fuel. About 3 years ago I took my WUR apart and it was clean as a whistle w/ no sign of corrosion at all. I've always used Stabil during winter storage. Lately I've switched to the one made for use w/ ethanol fuels.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 11-02-2012 at 07:18 PM.. |
Thanks guys for all the feedback, I really appreciate it.
Je Ne Sais Quoi = Targa
Turn the heater knob(s) on (up, closing the doors) keeps mice from building nests in the heater system, I Don't unplug the battery, but do use a battery tender, Leave hand brake off, Car cover on, Never added stabilizer, no problems yet,
'74 Targa lightweight widebody, 3.6 motor, big bars, Speedlines, Sold 2018, '81 SC Targa with 3.2 spoilers, Webers, SSIs, 7&8X16 Fuchs, 911R style exhaust, Had a '71 911S Targa in the 80's, miss it, Had a '61 Roadster in the 70's, miss it also, |
Thanks. |
Fresh oil, stabl, wash, disconnect battery, car sits on dollys. I have critters sometimes in my garage (heated to a point) so I like the idea of closing the heater boxes and covering the fan. I hook the battery to a tender. Bought a Ctek tender for both the car and cycle batteries.
'84 Carrera (recently sold )'67 MB 250SL A few Italian motorcycles ......and a minivan for the crew |
Idling air-cooled motors stationary is even worse; they locally overheat (at least, ones without fans do). Oil on my 930 gets hotter in traffic than it does on the track... I've always wondered why warming up your motor by idling it seems so ingrained/popular in the US.
'77 S with '78 930 power and a few other things. |
83 Targa
What is the greatest concern about winter driving? Is it just salt on the roads or are we talking about proper garage queen care? I am new to this and have a low milieage very clean '83 Targa, but I am inclined to drive it anytime the roads might be dry for exercise of every component and seal. If its just salt, I will scrub the bottom for care. Thoughts or comments welcomed.
Yeah.....I don't get the whole "start her up" every month during winter. Its -30C here in the winter.....any idea what kind of wear your asking for there??? No Thanks!! Plus I don't disconnect the battery, charger on auto trickle, in the garage, Stabil, wolf "softie" car cover and parked in the cold garage.
I've driven alot of crap to get here man! |
anyone use a battery switch? any benefit or drawback to using this?
